Aor 8600 reset to factory default
on3rvl
gijzegem Belgium
Still Blocked !
Thks for advace , but i am still blocked .
i am focussing now on "global protect" but when i follow this in the manual nothing happens .
When you have any idea please let me know
Kind regards
Raymond
cabletech
Puget Sound
Why do you need to reset to factory default? For a USA $2000.00+ reciever if it is that bad, you better contact AOR directly.
theoldcop
Wilmington, NC
Have you tried this (from section 19-1 of the manual)?:
19-1 Soft reset of microprocessor
If removing power and switching the AR8600 off / on does not help, try a soft reset of the
microprocessor. Soft reset is achieved by powering-up the radio with the CLEAR key held, do not
release the CLEAR key until the opening message has performed and a frequency is displayed in
2VFO mode.
All scan & search environments are cleared, bank link is set off and the receiver frequency will be set to
88.000 MHz for both VFO-A and VFO-B. The beep will be enabled and set to default as will lamp and
LCD contrast. All memory and search bank data will be intact.
Good luck.
John
on3rvl
gijzegem Belgium
Aor8600 memory problem
Thks John for your awnser , but i already tried this out , with no result .
I guess one of my grandchilderen played with the radio and something id blocked but to find this is not easy .
If you know other things i need to try pls let me know
kind regards
Raymond
theoldcop
Wilmington, NC
Raymond,
When you refer to "Global Protect" do you mean "Write Protect"? Also, do you have the EM8200 installed?
John
on3rvl
gijzegem Belgium
Write protect !!
John ,
I dont' know what you mean or where i can find write protect !!
No i dont have Em 8200 .
Thks anyway .
kind regards
Raymond
theoldcop
Wilmington, NC
Section 11 of the manual explains write protect. Apparently nothing in the radios database can be changed or deleted if the write protect is enabled.
I would copy and paste from the manual but it doesn't copy/paste everything. If necessary I can paste and then send the info. to you via email. Let me know.
John
on3rvl
gijzegem Belgium
Problem Solved!.......
John, Thank you and thank to all the other people who tried to help me ! when i was trying without manual , and retrying wat Japan proposed me ( function + scan ) THE scanner closed . Difficult to restart but when hè jumped on all memory was deleted !.....Dont ask me wat i die ,but my problem is Solved!.anyway , i Will Buy another radio , but not decided with one . Kind regards. Raymond. On3rvl
theoldcop
Wilmington, NC
Well Raymond, I'm glad you got the problem solved, but sorry to hear your going to part with your '8600.
Best of luck with whatever radio you decide to purchase.
John
on3rvl
gijzegem Belgium
Aor 8600
Dear John ,
I will not part of the Aor 8600 = to nice radio , and i Always keep my radios even i dont use them .
but i will buy some new , but not decided what -)))
The moment i have my new radio i inform -))
Kind regards
Raymond
theoldcop
Wilmington, NC
Fine business Raymond. I misunderstood your comment, so I apologize. I LOVE AOR products and I own a 8600MKII and 8200MKIII (I also had a AR5000+3 but had to sell it for personal reasons). I am always learning something new and I find the settings very easy to change "on the fly" when needed. I know they don't scan quickly, but I have other radios I use for scanning. I use my AOR's as VHF/UHF receivers and the occasional HF listening as well. Like you, I do not always like to sell my radios (I listed them under my name).
Good luck with the next purchase and let me know which one you buy!
John
Microtelecom Perseus, Icom R75, Icom 746PRO, Uniden HP-1, 996T, 996XT, 396XT, BC780XLT and BC9000XLT. Radio Shack PRO-2022 and PRO-2045, Sony ICF-SW1, ICF-2010, ICF-77, Grundig Yacht Boy 400, Kenwood TH-F6A & TH-D72A. Icom R20 and 208H and, of course, my AOR 8600MKII (with ME8200 and CT8200 cards) and 8200MKIII. I use 2 Scantennas and 2 discones. I also have an Alpha-Delta DX-LB+, Alpha-Delta DX-Sloper and Quantum Loop v. 3
on3rvl
gijzegem Belgium
Still some problems -)))
John ,
I can fil in the program search banks , but separate frequencies are not possible ?
Do you know how come or a solution for this ?
Including some screen shots
a: search banks
b: difficulty with separate frequencies
Thks in advance
Raymond
theoldcop
Wilmington, NC
Raymond,
Seems like you are still in VFO mode. Try clicking on Stop/Mem. That should take you out of VFO mode and then you should be able to right click on a memory line and edit/enter a memory channel.
