Apollo Pilot XP (AL-A28) Programming Cradle
jbuchbinder
I've been looking for any engineering or wiring diagrams out there for the Apollo Pilot XP programming cradle (it's actually part of a multi-unit programming cradle, but I suspect it's just different connections to the serial interface) to reprovision some older second-hand Apollo Pilot XP units for fire service use. I'm aware of the hand-programming method for adjusting CAP codes, but I need to adjust other settings in the pager. Has anyone built an interface for these?
jbuchbinder
Included are pictures of the actual innards of the AL-A28 (excuse the grime, please, it was a damaged unit):
It looks like the right pin connects to the negative battery lead, and I'm not sure what the other two pins are for.
jbuchbinder
Upon deconstructing a charging unit, it looks like the left pin is ground. I'll conduct some further testing to see which charging pin does what, etc.
jbuchbinder
Confirmed that CHARGE1 is +5V, GND is the ground pin. I'm assuming that the middle pin is the data pin, most likely combining the TX/RX with a single diode. I'm going to continue testing using the guts of the charging rig to see if that assumption holds.
