Appling for streamer
32dave
Oxford County, Ontario Canada
I am trying to apply to become a streamer, But the system drop down doesn't list what I am going to stream how do I get around this as what I'm streaming doesn't apply
n0esc
SE MN EN33
If you are applying for a Calls node, then the system you are feeding must be in the RR database already as that powers the backend of the Calls system.
If the system is missing, you can submit information to the database first before applying for a Calls node.
Otherwise you can stream a traditional feed and choose Other as an option if none of the typical categories fit the description of what you are monitoring/streaming.
32dave
The services are listed, They are not trunking and the "other" option is not there. I guess I could put it under a system that I believe is dead and try to adjust it after I get the API
n0esc
SE MN EN33
Which service is it that you are trying to stream? The Calls platform only supports non-trunked (Conventional) frequencies when feeding using Trunk Recorder (Conventional) or VoxCall setups, where you will be given the option to list the specific frequencies you will be streaming. If you are selecting any other option, you won't see the Frequencies box, just the ability to select trunked systems that are already in the RR database.
"Other" will only appear as a choice when applying to host a standard live audio feed. Provided it is not one of the prohibited service types, and does not fit in the listed categories, Other would be a choice that shows where your feed type would be listed when searching for feeds using the filter options.
