APX open squelch monitor
rjvalenta
in CPS for the XTS - first option on the first page of the conventional settings - Monitor Type: Open Squelch / Silent
where is this in APX CPS? aside from 'Squelch Per Personality' i don't see anything in Conventional Wide.... nor do i see it in the Conventional Systems or the Personalities.... what am i missing?
how do i make it so an APX will go open squelch static when someone touches their monitor button?
thanks
Asunakiyori
Lurker
Hiding in a Shed somewhere
conventional wide top of page
thanks
rjvalenta
i went and looked (shown below) and i'm not seeing that... then i opened XTL CPS and realized that it's not there either.
i will assume that because i am working with an APX Mobile it is different... anyone know how to make this work with a mobile? or if it's possible?
GTR8000
NY/NJ Database Guy
BEE00
Are you in expert view?
Expert view isn't going to make any difference. He's asking about an APX mobile, which doesn't have the Open Squelch Monitor Type parameter in any CPS view.
The trouble is that the OP is referencing an XTS portable in his first post, but asking about an APX mobile. He should've led with that key bit of info.
GTR8000
NY/NJ Database Guy
BEE00
Put the MON button in the menu list. Push and hold MON I think puts it into no squelch condition
Negative. Long pressing the MON soft key gets you to the squelch adjustment for that channel, it does not put the radio into open squelch.
The best you can do with a mobile is to long press MON, drop squelch down to 0, then short press MON to defeat PL, which blasts you with white noise.
