APX7000 Scan Issue please help
firedog348
My MOTO APX700 will TX and RX on any selected channel but will not scan my programmed list. I have double checked everything that I know to and I'm coming up short. This is a trunked P25 system, Is there a setting in the software that I can check? I have compared another radio's programming side by side and I cannot find the differences in the programming. One scans like it should and the other not so much. Any help would be greatly appreciated!
firedog348
Make sure your personality is assigned a scan list as well as the channel is assigned in the scan list. Common mistake
Thank you for the reply. I have verified that the scan list is assigned and attached to the personality. What's weird is the display will switch to the channel that is transmitting on scan but there is no audio. When you manually turn over to the channel the audio comes through, just not while scanning. This one is driving me crazy.
Tech21
Trunking personality > Zone ____ > Scan > Scan list selection > whatever system you are on.
Verify that for each trunking personality.
Also, make sure you don't have duplicate ID's in the radios since you said you tried cloning them. Trunked systems absolutely hate duplicate ID's. You can verify this by keying up both radios one after the other and verify the ID that comes across the screen. If it's the same, that's a problem.
