APX7500 Programming Help
APD242
Allendale, NJ
Hello. I am having trouble connecting my APX7500 radio to the CPS software. I have the O3 handheld controller, therefore I am connecting the programming cable to the radio itself. On the radio is a typical round twist type connection similar to the xtl1500 mobiles. Also there is a serial connection which I am trying to use to program. The CPS wont detect the radio through the USB port. I tried numerous computers, all no result. Any and all help would be appreciated. Thanks
vans113
Tennessee
Never used this remote head only used 05 remote heads and they have a spot. If not I think you can program on the blue plug on the radio itself but I'm un sure on this
Sent from my iPhone5 using Tapatalk
Tech792
Central NJ
Sounds like you're doing everything correctly. Did you mess with the port settings in the CPS? I think its up top under "file". The CPS might be set to a USB port you're not using. (Don't have it on this PC otherwise I would look) You might have to change them or try different USB ports on the PC.
jim202
New Orleans region
The port setting is important. If you don't tell the computer what port to use, serial or USB, it will never find the radio.
It is also better to start the radio software up and get it running before you make the connection to the radio. If the drivers are not set up already in the software, it won't work. So letting the software start up and be ready for the radio, when you attempt to make the radio connection, the software should install the driver needed if it has never done that before. The software is contained within the CPS.
The other item to be aware of is the computer giving out with the audio tones that it sees the interface cable when you connect it to the computer. It should all ready be connected to the radio first.
Depending on the cable your using, it could be the round mic type connector that would plug into the round mic connector looking connection on the faceplate of the radio or the DB connector on the radio. No RIB box is required for these cables. The accessory connector is probably a serial connection and you would need to set the software accordingly. However, there is USB connections there and you could make your own cable if needed. I have done this before.
Let us know how you make out.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Typically plugging a usb programming cable into the gcai port on the front of the drawer results in a "NO USB" message on the O3 control head.
Get a 26 pin accessory port programming cable. It can be a usb or serial cable. Or buy the cheaper one and add the pins to make the other.
APD242
Allendale, NJ
Thanks so much for the replies! I am using a small Motorola serial plug which in turn goes into a larger pin plug on the top of the radio. For some reason, the computer is not recognizing that the radio is connected to the radio via usb. I will try to post a photo of the cable to ensure I am using the right cable
APD242
Allendale, NJ
I tried to upload the photo, but couldnt. I am connecting to the radio 25 pin by using the stock accessory cable which connects to a small motorola 26 pin connector. Does this make sense?
wsykes41770
Rochester, NY
Correct cable
The APX7500 can ONLY be programmed through USB. Make sure you have the red ignition wire plugged into 12VDC or you won't be able to program the radio. The latest version of the APX CPS is version R12.01.00. It was just released a few weeks ago. You have to have the control head plugged in and the radio turned on or it won't work. Insure that your USB ports on your computer are working as well. If not, then you won't have any luck.
