APX8000, Who Has One?
KE4ZNR
Radio Geek
I knew I had one of those Bluetooth RSMs here in my shop!
Just had to find it and charge it up.
Here it is paired to my APX 6000:
Marshall KE4ZNR
ts548
Marshall KE4ZNR
I’m liking my so far.
K2NEC
NA
Anyone recommend the mic? I am on the fence about getting it for my 7550e.
Pros/cons?
ts548
Pros/cons?
I don’t believe I will go back to a wired mic unless someone just gives me a XE500.
MTS2000des
5B2_BEE00 Czar
Not good for crowded BT environments
During last year's college bowl playoffs, the BT RSMs were unusable on our 8000s due to BT pollution. A crowded stadium full of people with smartphones rendered them useless. We broke out our XP corded RSMs.
SuperBowl 53 meetings have told us no BT accessories for LMR radios will be permitted inside the venue. Hardwired RSMs/audio accessories only.
K2NEC
NA
Noted thanks for the info!
kjl13
Interesting.
ME801
NV
Interesting, I thought /\/\'s BT LF MPP was incompatible with consumer BT devices. I had to enable LF MPP in my CPS (R16.01.02) to pair with my BT RSM. YMMV.
Thunderknight
Bletchley Park
But if it uses the same spectrum, even if the protocol is different, it will still suffer interference.
ME801
NV
Hadn't thought of that.
Matt9638
Good evening
Question for everyone, can an APX8000 housing be switched out for an 8000xe housing? Thanks and happy thanksgiving
K2NEC
NA
Good evening
No it cannot. The 8k housing can be switched with a 6k housing but not with an XE housing. Different components.
akardam
Well, no and yes. In order to make an 8000 non-XE look like an XE, at least from the outside, not only does one need to swap out the main "wraparound" plastic shell of the housing, but also the control top and the knobs. The control top bezel/knob assy is an integrated unit that includes the top display and channel/volume knob electrical components (switcher/pots) with an outer plastic overlay.
If one is keen to try this, one can examine the BSM for the exploded views and parts lists, and try and aquire all the necessary bits.
Of course, adding the XE flashcode option to a non-XE radio is a whole 'nother task...
MTS2000des
5B2_BEE00 Czar
The limitation is due to the shared spectrum. In close quarters to literally thousands of devices, wireless access points, and everything else imaginable, BT becomes venerable to interference.
Anyone who's worked an NFL event knows they regulate EVERYTHING. Their frequency coordinators require a complete inventory of anything that radiates RF. They said "no Bluetooth accessories on two way radios". Their event, their rules regardless of the interference making them unusable during our prior event in the same venue.
scrotumola
So. Texas
Awww hell.... add me to the list of those with an 8000.... and the BT RSM.
Building this codeplug, however.... wow. I wish migration from earlier lines was easier.
~S~
ccsochp11
SACRAMENTO
Here's my baby
