APX APX900 NAS issues
chrismol1
Yes, it is coming from a nearby TRS. The "SYS" is displaying the system's WACN, followed by "-015" - still don't know what this indicates. It seems that it is only displaying when dispatch transmits, NOT when other units are Txing.
Ah okay yea, displaying the WACN and the sys id or something alternating display message interesting, so it displays the wacn and 015. as N4DES said and I was thinking, roaming or something linking. I've encountered that before where the sys id & wacn displayed on received transmision.
Still interested in your issue of the non-scan list talkgroup coming thru on top of everything else
IAmSixNine
Dallas, TX
To add to commercial radios that can program with no TX, the BK KNG and KNG2-P800 will do this. It was designed with RX Only in mind and has a single check box to enable it.
Must have something to do with the wonkiness of scanning a Harris system with a Motorola. Thank you for the help.. going to desperately look for a change in radio LOL.
natedawg1604
Colorado
What's wrong with a Uniden SDS100? Pro-tip: you'll never have to worry about committing a felony or two because it won't ever generate RF or affiliation requests. It's also easy to program: just enter a zip code.
It certainly does not have the same quality RF filters, intermod rejection, sensitivity, audio quality, physical build quality, or battery capacity/capabilities (i.e. battery smart chip) as a APX or Harris XG radio. And setting up NAS is absolutely trivial if you know what you doing.
MTS2000des
5B2_BEE00 Czar
Except no one ever got in hot water for programming a scanner, nor does it require using gray area system keys not authorized by a system owner. I get it, everyone wants a "superior" cop radio- but an SDS, Unication or Blue Tail require ZERO gray area/questionable software, don't have transmitters, and are comparatively EASY (especially for a novice) to deploy. Bonus: one doesn't get negative attention for potential piracy.
APX8000
Sarcastic Member
AES-256 secured
My Motorola subscribers work just fine on Harris systems. What radio ID are you using and on what system ID ?
junior71
As I already stated put Txin in your menu and use it. The radio will send no voice or data. That will take care of the Harris system problem. But of course you must make sure your NAS was done correctly in the first place. Plenty of guys out there that can do it the right way.
It has always been in the menu and it is always on. I never turn it off.
junior71
Then somebody programmed your radio incorrectly plain and simple.
chrismol1
The firmware version is R29. Tx is inhibited THRU THE MENU, like you said. Upon clicking PTT, it virtually displays “Tx inhibited“ where the UID should be. It is a SmartZone system and Motorola Prop Features IS checked.
This is also what I was thinking, which is why I am a little confused. I haven’t heard any transmissions since.
If you indeed have TX INhibit enabled then there will be no transmissions from the radio, then the items on the display when receiving will be some sort of function of receiving that system and the programming. If its a Harris system uncheck Moto Prop Features, I don't care if someone says it doesn't matter, uncheck that if you're not on a Moto system.
Make sure this is a SmartZone & Omnilink for the coverage type stuff, some Harris systems use differing RFSS type stuff and its possible you need Omnilink stuff enabled
Note: RR Experts I'm not an expert, these are no absolutes but continuing discussions on the topic
clbsquared
Isle of Wight County
If your radio is programmed correctly, this thread is a waste of time. It seems to me that you know better than the experts trying to help you. Unless, that is, you’re willing to post your codeplug for the experts to look at.
If you genuinely want help, then let’s see the codeplug. What are you trying to hide?
