APX APX900 NAS issues
junior71
If you indeed have TX INhibit enabled then there will be no transmissions from the radio, then the items on the display when receiving will be some sort of function of receiving that system and the programming. If its a Harris system uncheck Moto Prop Features, I don't care if someone says it doesn't matter, uncheck that if you're not on a Moto system.
Make sure this is a SmartZone & Omnilink for the coverage type stuff, some Harris systems use differing RFSS type stuff and its possible you need Omnilink stuff enabled
Note: RR Experts I'm not an expert, these are no absolutes but continuing discussions on the topic
You correct on moto prop and I found it best to disable coverage type for Harris systems.
