swfluncensored
- Joined
- Apr 11, 2023
- Messages
- 132
- Reaction score
- 12
Is the "Full Spectrum Control Channel Scan" checked off or on?
It is checked off.
would you happen to have that talkgroup in the announcement group box in the trunking personality?
It is not in the announcement group box. There is no talkgroup set to it.
Put the TX Inhibit option on the menu and enable it, then put the antenna back on, What does it do then? Is it set to smartzone/inter/intra wacn? Are the only control channels for that particular system in that specific trunking system? As asked above, is full spectrum scan enabled?
I have always had the TX Inhibit option on the menu, and always had it enabled. It was still doing it. The system is set to just Smartzone WACN, and full spectrum scan is not enabled.
That right there seems to be a common factor. That the problematic system is in fringe coverage. It's like the radio doesn't quite obey its own programming rules when it's in a fringe reception scenario.
Would this same issue occur on a Harris?
