ARC536 Basic bug
N0GTG
Scanner programmer since 1997
Denver, Colorado
I've found that if I am in a trunked system's radio ID's, and try to find a radio ID or alphabetic alias using the Frequency or Alpha tag field, I get a 'Run-time error 438; Object does not support this property or method'. Then the program crashes, taking with it all the changes I have just made. Save your changes frequently!
ofd8001
Louisville, KY
I just checked in the ARC536 PRO and the same is happening there.
The Find function appears to work for other things but in the "Unit Id's" area is when the crash occurs.
