Baofeng Baofeng UV32/DM32
jewest
Baofeng released a new version of the CPS -- 1.41. It gives a false positive on MS Defender when installing the application. Looks like they fixed at least a couple of my reported issues. Firmware version is unchanged.
Not false-positive.. Defender SmartScreen warns you because the exe's are unsigned. A result of lazy developers.
Just a custom build of OpenGD77 at the end of the day. If they can't develop their own firmware then I doubt they could pull off anything malicious.
rescuecomm
Travelers Rest, SC
I suppose you reported the reversed enc/ decode issue? On another item, does turning off the GPS make the battery last longer? I can't see any real difference on my limited testing.
devicelab
Radio N.E.R.D
WA (USA)
They fixed a couple of spelling errors. I didn't play with GPS so I can't provide any feedback there.
I did report the tone issue, but I'll need to verify the 141 build fixed that issue. Since my codeplug is rather set for the moment, I'm not eager to do a bunch of testing. If someone else can verify 141 fixed that issue then please do so.
BruceMichaels
Not "Some People"
Flying Over You
I know I asked this about 6 months ago, but has anyone been able to change the display from "Bank 1" to whatever you have named the bank? This is for the UV-32.
Thanks!
Falcon9h
Anyone else notice that with both of these radios that squelch sensitivity is poor on some frequencies, even when set to 1?
lamarrsy
Rimouski, PQ, Canada
Yes indeed, the squelch is too thight even at 1 (on my DM-32).
That’s why I went into the special settings in the CPS and readjusted the squelch to a lower level, more acceptable and more on par with other radios.
devicelab
Radio N.E.R.D
WA (USA)
Remember to also be on the correct bandwidth setting for that frequency. I've noticed these Chicom radios have a hard time with SQL and different bandwidths.
rescuecomm
Travelers Rest, SC
I just had a transmit problem trying to do a net check in on 443.450R/448.450T repeater. The display bar that shows TX power wouldn't indicate above 447.250. The net control said I was barely readable. I ended up reloading the program and it's okay now.
Interesting to say the least.
Falcon9h
Can you put the procedure up here?That'd be really helpful and maybe I'd use the thing for a change.
Wish the same could be done on the UV32 but no test mode in the CPS.
lamarrsy
Hello, really sorry for the late reply.
I had to be in front of my PC with the CPS open, to answer correctly.
Note that I have CPS v.1.41 and firmware 1.46.
The squelch can be adjusted (fine-tuned?) under « Tool(T) / Adjust mode » and the password of this section is 66660501.
When in this section after entering the password, *please* begin by « reading » your current version of settings in your radio by clicking on « Read(R) » and then SAVE this to your computer by clicking on « Save(S) ». Chose a naming that will tell you it’s the original settings that you are saving.
This is essential to do, because each radio has its *own* settings. In case of screwing something up, you’ll be happy to have this original settings saved in your PC, as you can’t even « borrow » the original settings of another radio.
The squelch settings I have changed are on the right side section (« RXFunc Items ») : the columns 1 2 3 4 5 of this grid correspond to the 1 2 3 4 5 columns of the bottom left section (« Freq Item »), which tells you which sections of the 136 (to 174MHz) VHF or the 400 (to 470MHz) UHF frequencies you’d like to adjust.
In my case I wanted to lower the squelch on the VHF section, namely the ~145MHz (column 2), ~155MHz (column 3), and the ~165MHz (column 4) of my wide (W) FM frequencies. I don’t listen to narrow (N) FM frequencies.
So… if you have followed correctly at this point (I just ‘hope my explanation are ok), you will now understand that I went into the right section, I clicked the box of « Edit RX/Other » to be able to Edit the values of the grid, and I lowered the values of columns 2, 3, and 4, on the line « SQ1 Open(136)(W) ».
My original values were 70, 70, and 80 (for columns 2, 3, and 4); My actual values are now 55, 55, and 65, which gives me much better receive in weak signals, for these frequencies ranges, without opening up too much on spurious noise.
Of course I have then saved (« Save(S) ») these new settings with a different name than the original Save, and I uploaded them to the radio with the « Write(W) » command.
I really hope these instructions are clear enough !
And I cannot insist enough on the recommendation of *saving your original settings* before doing anything in this section.
I have not explored any of the other settings, as I am not in need of any changes in other parameters.
Still, this is a very risky manipulation, and I cannot be responsible for any goof you may create !
Just be sure to SAVE - SAVE - SAVE the original settings before anything else !
‘Hope this helps !
-Sylvain, VE2LAM
BruceMichaels
Not "Some People"
Flying Over You
Thanks!
Just in case anyone else thought about this, I got a reply back from Baofeng support:
Thank you for your detailed explanation and screenshot.
After confirming with the supplier, we regret to inform you that the zone names displayed on the radio screen cannot currently be customized to show your renamed labels (such as “InterOp” or “EMS”). At this time, they will still appear as Zone 04, Zone 05, etc.
We have noted your feedback and will consider adding this feature in a future firmware update. We truly appreciate your patience and understanding.
CarlPB
Just an FYI, there is a prime day deal today (10/07/2025) on these. I'm still on the fence even with the sale due to all the mixed feedback. This would be a potential first DMR capable radio for me.
chief21
Western NC (Summer); Tampa Bay FL (Winter)
The DM32 still has a few warts, but the DMR performance seems pretty good - especially at the current price point. Get one!
robertwbob
KE0WRU
Northeast jasper county,missouri
hey jump in head first. might be your best or worse but not like buying a name brand expensive radio n discover you dont like it
VK2CRB
Sydney
I am in Australia and have recently purchased the Baofeng DM-32 radio but the bandwidth limitations posed a problem as our CB band is in the 477Mhz range.
I recently found this Russian site that has a firmware .bin file that was able to allow an expansion of the usable bandwidth 23-136Mhz and 220-520Mhz.
The new Firmware is dm32.01.02.46 which expands the frequencies.
I have updated my two radios and it seems to work vey well with even allowing the 27Mhz AM band programming (but not tested) although the 477Mhz has been tested and works well although you loose the startup picture but I changed this to show Voltage instead.
The existing CPS does not allow you to change the bandwidth in the program outside the listed 136-174Mhz 400-470Mhz but if you export to csv file and then update the frequencies and import the csv file back to the radio it all works fine and then the CPS will reflect the changes when you Read to and from radio.
Link to the site for the .bin file is Просмотр сообщений - Koshak
As far as I can see this is a great radio for the price with a lot more to offer I suspect.
Are you saying that putting the Russian firmware, after successful flashing the CPS 1.41 still will not allow to program channels beyond 470 MHZ ? That is not clear to me. I wonder if the hardware is prepared for that dynamic range in the RX and TX stages. Baofeng has no professional behaviour to answer, sadly. Thanks
robertwbob
KE0WRU
i bit the bullet but got uv 32 as dmr is dead here. main reason bigger screen for aging eyes. read reception flaw but im in wide open farm country n nearest neighbor over mile away. will try several antennas i got too never know whats best till you try em and use meter
devicelab
Radio N.E.R.D
WA (USA)
There's a new DM-32 firmware update and CPS version on the Baofeng Support site. I completed the upgrade to version 48 and it seems to be working fine. Read the Firmware Upgrade document BEFORE doing your upgrade.
(There was a 3rd step to reset the radio which isn't working for me. I sent email to Baofeng support so we'll see what they say.)
The new CPS is working OK too.
