Batteries blew up
Voyager
The black is for alkaline cells and is missing the charging contact. The yellow is for rechargeable cells. Even if you put rechargeables in the black holder, they will not charge.
retropcdos
Chicago, IL
Good new is repairable.
Before
After
Working on stripping the board, as have to repair then, mask it, Replacing the switch and SD slot.
Clean acid off this part of the casing figure check speaker while at it, since acid was around it, checks good and was able to neutralize acids
retropcdos
Chicago, IL
Started polish the copper on the board to mask and replate the contacts with gold plating/
Was a complete mess, as battery leak acid everywhere. Was able to neutralize acid and removed all corrosion out of battery compartment. Looks like noting happened.
retropcdos
Chicago, IL
Good batteries to use
SD card is corrupted, or damage, as lock up when trying to boot.
Try different SD card and scanner came to life works great.
Nasby
Ohio
Nice work!!
Great pics.
What did you charge for your work?
I'm sure it was kinda fun and satisfying to see the finished product.
retropcdos
Chicago, IL
Nice work!!
Great pics.
It depends on issue. If it simple as broken USB port then around $40 to $50 bucks. Component level repair, or PCB board damage then usually cost more Depends on model and issue. Good thing is pretty much can fix almost any issue, so long not a custom IC that can't be obtain, or crack multi layer board,
retropcdos
Chicago, IL
Awesome great job man !!!! You fixed that fast !!!
If it smaller I usually work on them right away, same as the WS1080 you sent. Only larger item like amplifiers, reel to reel decks, or test gear take a bit longer, as run out of space and have to clear a spot first.
buckbull
This is the 2nd scanner retropcdos has fixed for me in the past couple weeks . I couldnt be more pleased ....Great work !! Replaced usb port on whistler ws1080 and now this .
retropcdos
Chicago, IL
Everyone else please don't charge batteries in radios, as this is what happens. Use a good charger that has separate channels. A lot of others recommended some good ones in the past, here one good one, or the lacross, or MAHA powerex chargers. Recommend Eneloop batteries, stay away from the cheap china ones on eBay's that claim high mAh, as they are fake and lying.
