Its a pretty simple thing to explain, i see others have already said the same thing, but to further explain, again....
You will see that most if not all Ham Radio gear is sold with a fuse in the negative lead. Is it needed? Yes and No...
Yes: If you install it as the manual suggests and connect the negative lead directly to the battery then leave that fuse in the negative lead. Why? If the ground from the battery to the body/frame/engine of the vehicle failed all of the vehicles power load still needs a ground, your radio becomes a path to the battery ground. The fuse pops and saves the radio.
No: If you install it as you should in my opinion, the ground lead should be grounded to the body/frame of the vehicle at its mounting location. Now if the vehicle ground fails your radio is at the same potential as all the vehicle electronics, it has no ground and no power, no issues.
Why do they put that fuse in and suggest you connect it directly to the battery then? Well it can eliminate some noise in the receiver, and others think its a better connection, but in my opinion just do it the right way and bond to the body/frame at the radio. Motorola, GE, they have been installing their commercial gear this way for what 50 years? It's standard practice.
