BCD325P2 programming
bryonschultz
Renton, WA
Hey everyone,
I'm an IT professional of 30 years. So, my father in law thinks I'm a P25 expert and asked me to program his scanner. Told him I would give it a shot.
I did some research, downloaded FreeSCAN, got what I believe to be correct loaded up, but I'm still getting "Finding CtrlChannel" on the P25S groups. I'm not sure what I'm doing wrong, and I'm getting a little frustrated. Any help/guidance/advice would be greatly appreciated. I've attached the current config.
  • BCD325P2 4 sep.996.txt
shansmi
Do this... I do not have that radio but this video walks you through how to program a site on this radio.
hiegtx
Mentor
Dallas, TX
Hey everyone,
I presume this is the system you are trying to program:
Looking at your file:
The first two 'sites' (highlighted) are not valid for the {25 system. Those two 'sites' have Vhf-high conventional frequencies that are not part of the trunked system.
The three groups are talkgroups on the system.
The King County Public Safety has about 15 sites listed. Some, such as the listed for Regional Justice System, are likely for specific departments, and would not carry radio traffic for other departments & agencies. Two of the sites are Simulcast, which can be a problem for the 325P2. It does not handle that well. More on Simulcast in the Wiki. Simulcast Distortion - The RadioReference Wiki
The frequencies you have in the site labeled as King County match up match up to those listed for the King County/ValleyCom Simulcast.
Are you & your father in law fairly close to each other (your residences), or are you are in a much different part of the county than he is. If you program the site closest to him, but you are some distance away, then you might be out of range, so you would get the 'Finding CtrlChannel' message on the scanner.Similarly, if you programmed the clo0sest site to you, but it was significantly farther away from him, then while it might work at home for you, he, in turn would get the "Finding......" message.
Can you clarify where, in the county, you are, as well as he is? Like maybe a close highway intersection or something else that could be found on a map of the county? That would help determine which site might be best to program. You can delete those first two sites in your file (Renton Police and Tukwila Police) s they are not valid.
Ronaldski
MI DB Admin
Bay City MI
The Tukwillla and Renton Police ones you listed has 154/155 MHz frequencies, not seeing that on the King county page,. I suspect he told you to put those in as they may have been the frequencies they used before? Since they have talkgroups on the digital system, those aren't used anymore most likely. I would right click those two and Delete.
Items that are not trunked need to be have a "New Sys" made for conventional.
Seattle-King County Public Safety (KCERS) Trunking System, Seattle, Washington - There are a lot of sites listed for King county and your missing the vast majority so no doubt why no control frequency found. So you can make a "New Site" for each. I would though if you show a tower in your neighborhood on that list just at least put that one in. I suspect not all these talkgroups show up on each tower, so the scanner would spend quite awhile going to each tower listing till it came back to yours in turn missing some calls potentially.
HIGHLY recommend you only putting the frequencies that are shown in red as those are the control frequencies, the others are voice.
freqseeker
Puget Sound WA.
Correct it is type 2 analog. They will be migrating to a new P25 simulcast system soon.
Site 6 King County/ValleyCom would work best if in the Renton/ Tukwila area as they are dispatched by ValleyCom.
