bcd396xt
ncjones28677
Statesville,nc
I just received my scanner really new to it.I used a program called freescan to program the scanner which failed.I now do not have external speaker I only have headphone only is there a way to turn on the front speaker?
kennyloatman
Cumberland Co., NJ
Try pulling the headphone plug in and out a couple times. There is a problem with the headphone jack sticking on the 396t, Not sure about the 396xt.
wtp
Port Charlotte FL
me too
what i use is the end of my shoelace.
i have the 396t gf has the xt and hers has done it twice in two years.
i used to come home and plug mine into computer speakers and used battery power
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
You say FreeScan failed? Doubtful. What message(s) are you seeing? Do you have a USB-serial cable? Did you load up the drivers? What are you trying to load?
Too many questions, not enough info....Mike
ncjones28677
Statesville,nc
bcd396xt speaker.
I bought this scanner like condition off from ebay.
Everything was working great til I connected the cable to the desktop.
I was using freescan to load Frequencies into the scanner.
I was getting errors but that was caused by the Open
band editor.Freescan worked fine the data cable to the scanner came with the scanner.
I am able to and have the scanner loaded with data.My problem is for some reason the external speaker on the scanner has quit.
I am not able to get another scanner since he is not running a business.
As of right now I am using an external speaker for sound but I can't really carry it around like this.
I am trying to find a place to repair this scanner but I am not able to find a place!
I have tried Uniden but get the run around.Seems like Uniden is selling junk if that many people need repairs to the point you have to cut the phones off!@@?
I don't want the money back I just need repairs done!
ncjones28677
Statesville,nc
All I want is for my scanner to work like it should?
Everything is working great.The biggest problem I have is the speaker?
If I use freescan and shut off the send custom radio setting.
When I use the setting it generates an error.
ncjones28677
Statesville,nc
This scanner is like new no wear no cracks nothing.
The scanner looks brand new.I received the scanner usps.Everything to my knowledge is working
just the main speaker is not.I don't know if the cable did it or had something to do with it.
I get full sound with earplugs.
fxdscon
¯\_(ツ)_/¯
Why not just contact Uniden Repair?
Product Repair
ncjones28677
Statesville,nc
bcd396xt repair
I have tried to call and call uniden you try it you will see thank you for calling and they hang up on you
kirk23
Pierrefonds (West Island Montreal) Qc Canada
Try fiddling with the earphone jack..they have tendency of sticking in the closed position cutting off the external speaker.. just turn your scanner on..set to an active freq like the national weather freqs..take a 1/8" audio plug and keep putting it IN & OUT a few times till you hear the channel. This sticking problem DOES happen with the 396's..
It's worth a shot to try....
fxdscon
¯\_(ツ)_/¯
The link I gave you was to Uniden's web-based repair center that instructs you how to get your scanner repaired. It's not a telephone....
ncjones28677
Statesville,nc
Statesville
I live in Statesville have heard Statesville on to 800 Mhz
I have the BCD396xt I can't believe I am not taken seriously!!!!
The FCC Data is correct my scanner is correct my ears are correct!@!!!
