A friend pointed this out and I thought it was strange so I checked it out myself. If I didn't look carefully I won't have noticed this. I'll make it simple and you only notice it if you have more than one Favorite ON and you have several Systems under each.
Example: I will use 4 Favorites and each Favorites will contain 4 Systems.
Favorites FQK 0, 1, 2, 3
Systems SQK 0, 1, 2, 3
You would think the scanner would scan as followed:
(F0-S0-S1-S2-S3)(F1-S0-S1-S2-S3)(F2-S0-S1-S2-S3)(F3-S0-S1-S2-S3)
In other words the scanner would complete Favorite 0 and all the sub-systems before moving on to Favorites 1 and it's sub-Systems. But in all actuality the scanner is scanning in the following order.
(F0-S0, F1-S0, F2-S0, F3-S0)(F0-S1, F1-S1, F2-S1, F3-S1)(F0-S2, F1-S2, F2-S2, F3-S2)(F0-S3, F1-S3, F2-S3, F3-S3)
It's scanning the matched System under each Favorite before moving on. So if you wonder why your scan order is out of whack and you might be missing something, this may be whats causing it. Again this is only if you have more than one favorites enable.
Thanks to my friend Doug for point that out. He's running a bunch of Favorites so he was able to pick up on that right away.
