I have a similar problem with 996xt. It looses connectivity for data flow. Only way to solve is restart computer. Does anyone know what the port settings should be? I am using a USB to serial adapter.
The problem may appear similar but it's not similar and the root cause is different. What kind of USB Adapter are you using? Have you tried another USB Adapter?
The Port Settings in the Win Device Manager USB Serial Device Properties such as Bits per sec, data bits, etc. does not matter and will have no effect. Those settings are for antiquated Modems. Just make sure the port number in the Win Device Manager matches the software using and the scanner Baud rate matched the software using.
