Some systems I cannot turn off using Quick Keys while scanning. The system numbers in question show up on the display after "SO:" but when I press the keypad number corresponding to the system number Quick Key nothing happens. The system continues to scan. This doesn't happen with all programmed systems as some of the others work fine as I am able to turn them on and off during scanning by pressing the corresponding Quick Key.
I also have one system I cannot turn on while scanning. It just shows the asterisk for that system but pressing the corresponding Quick Key does nothing.
What am I missing here? Not new to the 996T as I've had it for several years. Did I inadvertently change something in the settings that would cause this? Is there a way to "lock out" a system so that it can't be turned on and off via Quick Key while scanning?
I'm currently using ProScan for programming but also have FreeScan available.
