Glen_at_OES
After a short time successfully receiving both conventional and trunked system scans/comms, the 800MHz trunked comms fail. When the scan shifts to the trunked system, it only displays one of the 10 freqs programmed, but not hit on any comms from IDs in it's two jurisdictions. It can continue to scan/detect the conventional freqs fine. After an hour (or so..) the trunked system will begin to work again - detecting comms on most of the 10 freqs - only to drop out later. The Force Dispatchers do not notice any comms problems - so I have to suspect the 996XT.
I hand programmed the trunked system using the info obtained from RadioReference DB. I downloaded the factory codeplug, and used that to build my trunked system. It seemed to work fine for the first day - both systems and all trunked freqs. Good strong signals - full quieting - no over-squelching used.
I welcome suggestions to help me fix this problem.
BCD996XT Firmware: 1.03.02
ARC-XT PRO used to program
