BurbsGuy
BCT8 No "ID SCAN" after firmware update - Montco PA
Updated firmware on two BCT8's as per instructions to follow a rebanded mot2 800 system. Now i can not get scanner to ID SCAN. Have tried manually inputting rebanded systems as well as using ARC8 with same results.
Although uniden said firmware was needed for rebanded, my system (Montgomery County PA 800) actually worked fine with old firmware. Yes, I should have left alone
So i have one BCT8 with old firmware that scans the 800 rebanded system fine, and two with updated firmware that simply SCAN and do not pick up.
The older one does the familiar B1 and ID SCAN and shows the scan id lists turned on. The updated ones simpl show active bank numbers and SCAN
Welcome all advice or a link to old firmware (can we go backwards?)
