Beam Issue
skyview
Colorado
I recently installed a 5 element 220 beam on the roof (well had help, I didn't/cant go up). To reduce torque on the mast, we mounted the antenna to the mast between the 3rd and 4th element, balancing nicely. But, the beam is performing rather poorly, the same but definitely not better than an omni. Did mounting between the 3rd and 4th element result in an issue in performance. Again, the beam works almost the same as an omni.
Thoughts.
Thanks.
K4EET
Chaplain
Severn, Maryland, USA
What is the antenna make and model? How did the instructions say to attach it to the mast?
skyview
Colorado
OK, so this is vertically polarized. Instructions made no mention of just how to mount. This is an Arrow 220 5S and is solid aluminum. Coax fairly new, and if I compare to a omni works equal, just not providing directionality.
K4EET
Chaplain
I probably should have cited the URL to the instructions. Pages 1, 4, and 5 have details on the end mounting hardware.
skyview
Colorado
Ha, that sure says end mount! I dont recall that diagram but maybe I was supposed to look online, which I didnt. Will have to arrange for someone to get up and fix mount. Thanks! I know we were completely confused on the mounting bracket itself, unable to figure out instructions and I fear thats where all our attention was.
Golay
Nankin Township Michigan
Yeah like K4EET has pointed out, needs to be end mounted.
Right now you have a six element beam with one element WAY out of resonance.
skyview
Colorado
Hopefully week after 4th of July can get it adjusted, bad thing is mount is so hard to work versus the normal ubolt. Still someone on the roof so hopefully can adjust. Ill report back if get end mounted, no doubt big difference.
  • Like
Reactions: wtp
K4EET
Chaplain
Once you have the antenna end-mounted, what will you be using to adjust the Gamma Match (Page 3 of the instructions)? Will you be using an Antenna Analyzer or transmitting with a radio (use low power) and a VHF SWR/Wattmeter? When adjusting the Gamma Match, first make sure the beam is pointed where you want it to be pointed (if you are not using a rotator). Then when checking the SWR, make sure the person on the roof is at least 10 feet away from the antenna while making the measurement. That is to avoid any interaction between the person and the antenna. Adjust the Gamma Match in small increments to find the best SWR for either your primary frequency of interest or the middle of the range that you will be transmitting on.
Coax fairly new
By the way, what is the nomenclature of the coax that you are using and the run distance to your radio? Depending on the distance, 220 MHz can have a significant amount of loss with certain coax.
You are close to having a great antenna system. Keep us posted on what you are doing and how the end result turns out.
skyview
Colorado
Should get remounted next 2-5 days and will report back, but yes, balancing the antenna on the mast was WRONG choice... sadly tough to access it. Ill update on performance changes.
Run is about 75 feet, using LMR 400 cable
Golay
I'm not sure I agree that the antenna has to be on the roof to match. I myself have no qualms believing if I can get a good match on the ground with no obstructions closer than a couple wavelengths from the antenna, I'll have a good match up on the roof.
K4EET
Chaplain
… if I can get a good match on the ground with no obstructions closer than a couple wavelengths from the antenna, I'll have a good match up on the roof.
You might get the match to be a minimum at 1:x SWR on the ground. Once you get it reinstalled on the roof, if that changes upwards to an SWR of 1:y, then you will probably want to readjust the Gamma Match to see if you can get the SWR back down to 1:x or even lower. You really should tune the antenna in its final resting place to be sure that you have the best SWR possible in that environment.
skyview
Colorado
Soooo, antennna is down, with proper mounting bracket on end. Now trying to get someone to take it up and reattach. Not easy to find the help.
K4EET
Chaplain
Did you adjust the Gamma Match with some form of an antenna analyzer for the mid-frequency of your interested frequencies? You can try doing that on the ground with the antenna mounted to some pole out in the clear but it would still be better to tune it in its permanently mounted location.
skyview
Colorado
So after a bit of time, the antenna remounted, with correct mount and gamma match. Sadly, although slightly better, compared to an omni, just not much gain. So disappointed in it. Not worse than an omni, just not much better (10-15%). Thanks for all the suggestions, I appreciate it very much!
