Should we be scanning only north or only south? Could the cutting out be the fact that it is scanning to the south when the better one is north?
Cant even pull a control channel in at 1 mile into Montco with a PRO-668 . 800/700 yagi , vert , multi band vert, paperclip , or a wet noodle ........ good thing i got this on the cheap from craigs list and scans Montco perfectly.......
This wouldn't be an issue if they would get our APX's onto the Berks systems... Getting someone to answer us from up there on the interops repeaters on mutual aid is like pulling teeth.
What process are you using that is resulting in you not being answered?
A few weeks ago there was a mutual aid dispatch for units to respond for a structure fire in Berks. Units went responding on 8call90, when asked if patch was setup on any of the 8 tac's, Berks responded with operations are on Fire Ops 1. When replied that we don't have those capabilities and that's the reason for the request and for the responce to Berks on 8call90,there was no response. About 8 minutes later , a phone call was made to the comm center to get the status of requested patch, the entire 11 minute response time to the scene was spent on the phone, including with a supervisor. Was first asked by a call taker if we responded on U tac , advised it was 8 call 90 as we ( Montco) units operate on 800 MHZ , then put on hold, then transferred to supervisor. When explaining the whole thing over again and why we asked for the patch, was asked if responded on 8 call 90 , explained yes and the supervisors response was " so whats the problem" . Had to explain that the problem was that we asked for a patch and one wasn't granted or even acknowledged and we were responding in deaf, couldn't get incoming instructions etc
Thanks. I will look into this.
