Best 2M Antenna for Apartment Patio
I can vouch for the Ed Fong dual band antennas. The best part of it all is that it's shipped in a small sandwich bag. All you need to do is buy the recommended PVC pipe grade (in the instructions) at Lowe's or Home Depot for a few bucks. Slide it in and it's done.
plughie
Coastside, CA
I have 3 of them: a dual-band base, a tri-band base, and a roll-up for the go kit. If you live in the Bay Area, you can pick up pre-assembled units at Ed's house if you contact him to arrange it. I'm sure Ed gives fair warning, but if you assemble it yourself, use the recommended schedule PVC pipe or you will move the center frequency of your antenna. The tri-band doesn't ship in a baggie because of the careful tolerances of the 1.2m coiled radiator.
As far as a recommendation? They just work, and have SWR of <1.1 on all 3 bands of my tri-band.
There used to be a guy in San Jose that built really nice aluminum J-Poles for 2 meter, 220, and 70cm. He sold them at the Foothill College radio flea market many years ago. I had a few of them and they were good antennas. Solid aluminum elements, well made.
Of course that was a long time ago. The radio flea market was bounced around to NASA and then De Anza. I haven't been in 2 or 3 years. Not sure if the guy is still around or not.
AI6VX
Ventura, CA
Given the choice of an Ed Fong DBJ1 vs one of the ~ 6' verticals from Comet/Diamond/Jetstream which would be better? I'm looking at getting a Jetstream JTB3 which is only $18 more than Ed's antenna.
AK9R
Central Indiana
J-pole antennas are an end-fed half-wave antenna. Their gain is about the same as a dipole.
If you are referring to the Diamond X50 or Comet GP-3, they are decent amateur radio antennas. Don't be wowed by the gain numbers, though. The Comet and Diamond antennas typically use dBi even though they often don't clearly state that. To convert from dBi to dBd, subtract 2.1. For example, Comet says the GP-3 has 4.5 dBi of gain on 2m. That's 2.4 dBd.
dBi is gain relative to a theoretical isotropic radidator (a single point that radiates equally well in all directions). dBd is gain relative to a half-wave dipole.
I would avoid the Jetstream antenna as it's a Chinese knock-off of a Diamond/Comet antenna. Inexpensive, but I question the build quality and long-term reliability. That said, the Achilles heel of most fiberglass radome vertical antennas is the joint between the radome and the base. If the antenna flexes in the wind, that joint will weaken, loose its seal, and allow water to enter the base of the antenna resulting in poor SWR and corrosion.
mass-man
trying to retire...
Parker Co., TX
A log periodic is designed to be wide band, forsaking gain. A beam for 2 mtrs is extremely easy to build...plans a plenty on the www!
AI6VX
Ventura, CA
Thanks much! Converting the gain to dBd, the X50 and GP-3 is about the same as a dipole. Maybe I should just build a 2M vertical dipole first and keep my $$ in my pocket.
Blackswan73
Central Indiana
A J pole is easier to build, and conceal. Twin lead is still easy to find, and plans for J poles and Slim Jims is all over the internet
TheSpaceMann
Just build a simple 2 meter ground plane! I once made one out of coat hangers and an old SO-239 connector! It cost me nothing and it took only about 15 minutes to build, and the performance was similar to a jPole! :)
AK9R
Central Indiana
A j-pole is easy to build, but they are 3/4 of a wavelength long, so you have to deal with the height. If you build one out of twin-lead or ladder line, as if often suggested, you have to support it somehow. Alternatively, there are lots of plans on the web for building one out of copper plumbing pipe and those work fairly well. One thing to keep in mind about j-poles...they lower section where the two elements are parallel to each other is a transformer. That transformer can be disturbed by nearby metal.
A ground plane is only a little more than a 1/4 wavelength long. You can build one using an SO-239 chassis mount connector and some welding rod.
AI6VX
Ventura, CA
Thanks to both. Just received my TM-281A yesterday - no antenna for it yet so I'm going to give one of these DIY 1/4 wavelength ground plane antennas a try.
Question for you guys - is the bandwidth wide enough to have good SWR (< 1.5) over the whole ham 2M band?
wyShack
Campbell County, Wyoming
For most 1/4 wave antennas the SWR is good over the whole 2M band. Use good coax and don't use more than you need. Get the antenna up as high as feasible. Don't forget to weatherproof. Watch the RF exposer limits and remember PEP is 4 times average.
73
JoninNYC
White Plains, NY
73
Regarding RF Exposure and PEP; would a beab antenna negate this due to the fact that the energy is directions and I would be behind the antenna in the appartment.
JoninNYC
White Plains, NY
If I went with a beam antenna, would it need to be pointed exactly to the location of the repeater? How wide is the RF beam? If a particular repeater is to the right of the ntennaor even behind id would it still work?
TheSpaceMann
It's easy! I have mine on a PVC pole strapped to a chair with bungee cords! I just spin it around by hand until the S meter peaks. I also check the repeater maps on Amateur Radio Ham Repeaters
to find the exact position and location of the repeaters that I want to reach! :)
