RufusDawes
- Joined
- May 8, 2025
- Messages
- 64
- Reaction score
- 73
Agreed on the Icom 705, I know its a transceiver but only 10W... aside from that it is the best modern day portable SWL radio today IMO.
I have my eye on that receiver (Drake SPR-4).... how is it performing for you? My understanding is that is is double conversion.This is exactly why I got a Drake SPR-4 and loaded it with all the crystal ranges that I have any interest in. I like having one good radio with analog readout just in case. The one JRC receiver that I would like to own is the 505 but those are very expensive, too much for me.
As a thought, if considering the SPR-4, have you considered the Drake R-4B or C instead? It allows more adjustability (selectable filter widths and such) with the same performance and limitations. The R-4B/C with an FS-4 might prove a more versatile version of an SPR-4 with the same FS-4.
+1. The antenna is critical. It would be better to have a mid-level receiver paired to the best antenna you can install vs top-of-the line model with a poor antenna.The best HF receiver is nothing unless paired with the best HF antenna.
This opens up a whole other can of worms.The best HF receiver is nothing unless paired with the best HF antenna.
I always tell people when discussing most radio things to think of it as buying the best stereo stuff for your home or car then putting crappy sounding speakers on it. What would be the point. At that point, at least some people have understood it. I find this especially true with the younger hams we're helping out in the hobby, or some newcomers regardless of age.+1. The antenna is critical. It would be better to have a mid-level receiver paired to the best antenna you can install vs top-of-the line model with a poor antenna.
Oh yeah. It would easily go more than 6 pages!This opens up a whole other can of worms.
Panasonic RF2200.
I think this is looking at one of the least expensive properties of any receiver and has nothing to do with the most expensive and hard to design properties. A super sensitive receiver can pick up things on a coat hanger compared to a less sensitive receiver and the difference between the two can be a simple and cheap preamp section. I have various hand held and cheap HF receivers that will pick up much more on a 3ft cliplead than my old Harris RF-590 or current Icom R-8600.The best HF receiver is nothing unless paired with the best HF antenna.
So a mediocre receiver and my trained ears = the BEST receiver?One of the best DX 'tools' that tends to get overlooked is your ears, and what's in between them, and how you use them when DXing / listening.
If you don't listen carefully, you'll miss a lot. And it can take some time to learn how, and what, to listen for.
No and that's not what he said.So a mediocre receiver and my trained ears = the BEST receiver?
At a certain point of quality, the radio doesn't matter much. At one point, I had a bunch of pretty great ones, including a JRC 515, a 525, Several Icom R71A's, a Kenwood TS-850SAT, and old timers such as the Yaesu FRG7, and Kenwood R1000. Yeah, the modded 515 was the killer radio, but I could hear 99% of what it could hear with a couple of my modded R71A's and the 525 and 850. A stock R71A wasn't quite enough to hear the really really weak stuff. IMHO, a couple of antennas is almost a must, being able to switch between them sometimes made all the difference. For most of the time I owned my house, I had 3 antennas, an Alpha-Delta Sloper, a home brewed BIG "Slinky Dipole", which was fantastic on the low end, and Windom in the attic. I also had a "big stick" CB antenna, which worked well from about 26 MHZ up to the lower 30's.
