Best Portable/Mobile ecosystem: NX-5000 line vs Motorola R7 + XPR5000e
otobmark
NC
Haven't had a chance to experiment with a 5000 yet so I'm curious, do you know if it will record analog PTT IDs from FleetSync and MDC1200?
No, mine doesn't record analog ID's, only the voice and timestamp. My VP8000 DOES record MDC1200 ID's.
lucasec
San Francisco, CA
Just to confirm, yours does record this information for digital?
Does it get the digital caller ID + channel name, or all three of digital caller ID, talkgroup ID/name, and channel name? And it shows this in the recording playback menu?
Mine doesn't show any of that with the very basic 4 recordings to built-in memory feature. Definitely another reason for me to upgrade if so :)
otobmark
NC
Assuming you are referring to the NX5300 rather than VP8000:
ID and voice record appear to be separate systems. The SD card can store voice messages with timestamp as well GPS data. It does not store ID and channel data as far as I can tell. The radio itself stores digital ID's and channel information on incoming transmissions. I suppose one could match up the timestamps of the two systems and connect ID to voice recording.
lucasec
San Francisco, CA
Ah, yes this matches how mine works. Basically the stack function records IDs (but only the user ID and channel name, not talkgroup) with timestamps (though there is some weird de-duplication logic in the timestamps if the same user calls more than once in a short period of time). Recording function gives just the timestamp (the second blank field I see must be the GPS data, I am curious how that displays).
I think technically the stack may record analog IDs too, but it only records selcalls, so if it's someone just sending MDC ID without directing a call to a MDC user or group, it won't log anything. I need to get a second MDC-capable radio to test this though.
dryfb
Midwest
Yeah, stack will save analog select calls (assuming it's set up right) on all my NX radios. I use fleetsync instead of MDC but iirc it records the same way.
