Broadcastify Raspberry Pi Image v3.0 Beta
bamx2
Indiana
Thanks... now I see why it is failing.... now I just need to figure out the JSON. I didn't edit much, but I am getting a parsing error. Starting over from scratch.
jegallag
Bel Air, MD
I am running the Broadcastify 3.01 image and am unable to edit the Crontab file with Crontab -e. It appears the file is write protected but I have changed all permissions on the pi and root files in /car/spool/cron/crontabs directory.
Any ideas?
pi@Pi5-BCFY:/var/spool/cron/crontabs $ ls -l
total 8
-rwxrwxrwx 1 pi crontab 1156 Nov 19 12:43 pi
-rwxrwxrwx 1 root crontab 232 Dec 30 17:36 root
bamx2
Indiana
What is the reasoning for using Trunk Recorder vs SDRTrunk for streaming? IS there something I am missing? SDRTrunk seems to be much easier to configure.
IcomIcR20
SDRtrunk is more computationally intensive. It is barely functional on my Pi 4 while trunk recorder runs with zero issues.
bamx2
Indiana
Interesting. I’ve been running SDRtrunk this week on a vacation, and tested sending a stream to the other site and my pi5 hasn’t seemed to have an issue. I could not get trunk recorder to work for the life of me. Even had ChatGPT try to help me make my config file and it kept erroring out.
bamx2
Indiana
Update: About 5 hours with ChatGPT and I finally got the config file made. The pitfalls I ran into:
Once I gave it the data from the config readme, things went a lot smoother.
It kept wanting to put a control channel outside of my tuners. I ended up deleting it from the control channel list, and if that is a detriment I will work with it later, but I was having a hard time finding a center freq that would grab all 4 control channels and not error out. I don't want to get a 3rd dongle right now just for 1 control channel that I don't think rotates often.
I tried creating a webhook service to monitor with it also. We kind of got that working. Once again if I had a better understanding of webdevelopment I think I would have made it work.
I think it would be interesting to upload all of the documentation into a NotebookLM and see if that works better. I don't have access to it for personal use through.
bamx2
Indiana
Last update, learning to code some now with this, and with AI have been able to create some neat stuff. I get a telegram alert when the trunk recorder goes up or down, a status update with average cpu usage, uptime, and disk usage every two hours during the day. Also a call log I can open in HTML that rotates daily. and a telegram message if a call is started with the emergency flag as true.
Greencastle, PA
I was able to get the Raspberry Pi 3B+ up and running with little effort. One thing I have not figured out is how to monitor the audio input in real time (i.e. before it leaves the Pi for Broadcastify). I have a small HDMI monitor attached that has a built in speaker. I can play a test wav file via aplay so I know the speaker works but have not solved this need.
Did have major issues with Balena Etcher, it would say the flash failed but the resulting image on the SD card boots just fine.
Greencastle, PA
I gave up on the Pi, too many restrictions in place with the Broadcastify image. Went to an old laptop, installed MX linux on it and got darkice up and running. Really need to provide a way to monitor the inputs.
scotte
Regarding Broadcastify and Darkice, I get
DarkIce: IceCast2.cpp:258: Icecast2 - wrong password [0]
I am currently running my stream fine from a Windows 10 laptop but want to transition to my Pi 5.
Thanks for any insights
DC31
Massachusetts
Try correcting the error in your password.
password = XXXXXXX # source password to the IceCast2 server
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
could also be an invalid or incorrect mount specified.
scotte
I copied the password, server, port and mount point details straight from the Technicals link from broadcastify's Management URL into my darkice.cfg file.
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
Why didn’t you use the broadcastify configuration shell?
I’m willing to bet you didn’t enter the correct mount (you probably included the slash etc) or something else if you configured it manually instead of using the Broadcastify Shell that we provide that automatically configures the feed for you.
boonebroadcaster
NKY
Looking for some help here. I have been running a raspberry pi for months with no issues. Recently we have had several power outages that have forced the pi to reboot. Somewhere along the way, the pi went offline with the broadcastify server. Additionally, I am able to SSH into it without issues. VNC, connects but is only a blank image, no desktop. I have looked through the wiki, is there any commands that could be used via ssh to repair the build? I am currently away traveling for work and would like to remotely fix the issue if possible. I have ran the normal sudo apt-get update/upgrade commands, tried restarting “statx” without any luck. TIA!
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
The only thing i could recommend here is to reflash the pi with the image
brad2388
Climax, NC
Ive been runn op25 for about 6 years np. Today i decided to update. That failed.
So im here. Trying to figure out how to get the stream back up with this image.
Can someone help me get op25 back running?
