CALAW1 154.92000 Air Traffic
mcjones2013
Radio Communications Enthusiast
Sacramento, CA
Does anyone know who in Sacramento operates on the CALAW1 154.92000 frequency? I have it programmed into my scanner and it sounds like aerial surveillance of some sort. Doesn't operate all the time but every couple months I hear an air unit talking to ground units it sounds like. Maybe a personal message response if it's sensitive and someone knows. I know Sac PD CCAT units logged on the Sac TRS system today but don't know if they have access to a low-profile aerial surveillance unit.
154.920MHZ = CLEMARS = California Law Enforcement Mutual Aid Radio System.
It's a simplex channel used throughout the state. Most dispatch centers have it and many actively monitor it. Many agencies that use VHF for their normal communications have it in their radios. Most state parks law enforcement units have it, too.
You are probably hearing mutual aid traffic.
In my county (Santa Cruz) it's often used between dispatch centers and for BOL type traffic.
gmclam
Fair Oaks, CA
I heard the traffic on there today too. It wasn't mutual aid. Sounded like an agency just needing a frequency that radios had in common. Simplex also means less coverage area.
kma371
Did they give locations?
I know of A drug task force in the central valley often uses it for surveillance
mcjones2013
Sacramento, CA
I did not hear any locations specifically this time, however I have heard locations given in the past in the Sacramento area.
It's obviously surveillance or special ops based on the terminology they're using (i.e. Target, location 1, location 2, etc.)
I looked at the flight tracker for the airport system here around the time they were up and I think I found where they were but the call sign on the site doesn't match up to any info I have., "BAJA".
K6CDO
Hanover Co. VA
154.920MHZ = CLEMARS = California Law Enforcement Mutual Aid Radio System. ...
The names of the CLEMARS channels were changed to CALAW(#) in 2013, in conjunction with narrowbanding. 154.920 is CALAW1.
Don
kma371
BAJA belongs to the 912th ARS at March ARB
com501
The Alpha tags on half the radios in the state still say 'CLEMARS'......
Yep, so do all ours. Our dispatchers call it CLEMARS.
I changed their consoles and the radios to VFire21 from "Fire White" just last year. I have to do these changes slowly and carefully.
scottyhetzel
Palm Springs Area / OrCo
K6CDO
Hanover Co. VA
I agree, however there is a thread about the problems using the p.l. On the Rx side. It's on the L.A./ Inland forum. Basically not every agency is on the same page.
Agreed. From a technical issue, the problem with the RX CTCSS is that not everyone is transmitting 156.7.
f40ph
CC actual
Largest County, USA
...and the requirement to TRANSMIT 156.7 went into effect a year before the receive. Funny thing is the STATE agency called "CHP" can't manage to follow the STATE mandate from OES to get that encode in there.
Oh well...someday...
