California Radio Interoperable System (CRIS)
norcalscan
Interoperating Spurious Emissions
The real northern california
Most likely they could use Star-Link as a satellite solution most likely. Why not.
Starlink and every other satellite solution requires sky, open sky, with little to no obstruction. Everywhere 700MHz doesn't work (and even VHF in some places), is also where satellite won't work. Canyons, winding along rivers, creeks, with pines and oaks and redwoods and sequoias...Although some remote places after the Mendocino Complex and Dixie Fire are now unfortunately very satellite-friendly.
Pyramid vehicular repeaters was at APCO. They had the Viking multiband set up with Pyramid repeater setup similar to what CHP uses, on display. Attached to it was a Cobham BGAN radio/antenna.
May not work everywhere, but I know of specific places I work where there is no radio coverage, even on low band, where my satellite phone/Garmin InReach device works.
Not saying that CHP is going that way, only that the manufacturers are seeing it as a solution. If someone picks up that solution and uses it remains to be seen.
PrivatelyJeff
Has more money than sense
Kings County, CA
Plus the system only works when in a fixed point and doesn’t have near 100% daily uptime.
Soledad, CA
Not sure wtf was happening, but I was hearing morse code on my pro 106 analog and saw the site was broadcasting it's call sign on dsdplus FL also.
kg6nlw
Railroad & Ham Radio Extrodinare
Sonoma Co., California
I've been seeing the same callsign on a few different sites, it looks like the state has made an update in the FCC DB...
Regards,
-Frank C.
scannerboy02
Regards,
-Frank C.
It's the license for all of the states 700 MHz allocation so it should be broadcasting on any site that's using that allocation including conventional sites.
The 'update' is a response to the FCC wanting to take away part of the allocation.
kg6nlw
Typical FCC...
Regards,
-Frank C.
officer_415
SF Bay Area
So we have multiple sources now saying Site 53 is Rocky Butte. Before I make the change, does anyone know what Site 35 is? One source indicated it was "Toro Mtn".
officer_415
SF Bay Area
Disregard, apparently Site 35 was submitted in error. I will remove it from the DB.
MtnBiker2005
San Diego County, California
Site 1-16 Bay Area
(Just passing southbound via the small cruise ship and logged it today)
-TowerInfo
System ID : 9D2
WACN : BEE00
Tower Number (Decimal): 1-16 - Bay Area
Tower Number (Hex) : T0110
Control Capabilities : Data,Voice,Registration
Flavor : Phase 2
Call Sign(s) : WPTZ774
Timestamp : Thu Sep 8, 2022
Site NAC: 9D0
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.01250,1
01,762.00625,0.00625,30.00000,"Confirmed",0.01250,1
02,851.01250,0.01250,-45.00000,"Confirmed",0.01250,2
03,762.00625,0.01250,30.00000,"Confirmed",0.01250,2
06,151.00000,0.00250,0.00500,"Confirmed",0.01250,1
07,157.00000,0.00250,0.00500,"Confirmed",0.01250,1
08,151.00000,0.00250,0.00500,"Confirmed",0.01250,2
09,157.00000,0.00250,0.00500,"Confirmed",0.01250,2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"01-1772","c",773.08125,"01-1772",803.08125,0,0
"01-1848","a",773.55625,"01-1848",803.55625,0,0
"01-1884","a",773.78125,"01-1884",803.78125,1,0
"01-1972","a",774.33125,"01-1972",804.33125,0,0
"01-2052","i",774.83125,"01-2052",804.83125,0,1
__________________________________________________________________
-TowerInfo - Updated Log:
System ID : 9D2
WACN : BEE00
Tower Number (Decimal): 1-50 - Seigler Mountain, Lake
Tower Number (Hex) : T0132
Flavor : Phase 2
Site NAC: 9DC
-Tables
-Frequencies
"01-1184","c",769.40625,"01-1184",799.40625,0,0
"01-1384","a",770.65625,"01-1384",800.65625,0,0
"01-1808","a",773.30625,"01-1808",803.30625,0,0
"01-1854","a",773.59375,"01-1854",803.59375,1,0
CRIS Sites Pro96Com Reports on one page.
https://www.scandiego.com/viewtopic.php?p=8465#p8465
kg6nlw
FWIW, I have picked it up but I'm not sure where I was at the time...I have 9D0 as Site 1-16 and Site 1-20 (Loma Prieta).
EDIT ADD: It seems like most every time I heard 1-16 was in the lowlands of the bay, specifically nearby to EBRCS areas.
Regards,
-Frank C.
scannerboy02
Perhaps Sunol Ridge? That was one of the sites shown on the bay area map a while back.
N6ML
FWIW, my receiver in Brentwood is hearing site 21 (Nevada County?) on 773.08125. Sunol Ridge is shadowed by Morgan Territory, so I wouldn't necessarily hear that well.
LAflyer
Global DB Admin
Moderator
SoCal
Quite a bit of ENC activity on TG 139 on Lukens today among RID 307, 417, and 493.
bcorbin
Los Angeles
Interesting… all the traffic on 139 through Oat this morning was in the clear. I’ll look at the RID’s in a bit…
bcorbin
Los Angeles
Actually, the only RID that made it into the recording logs was 417, the rest are “N/A”.
TGID 2061 also had a short encrypted tx, again, no RID.
