California Radio Interoperable System (CRIS)
bcorbin
Los Angeles
sorry northern guy here what is CWIRS? and what you see and hear
CWIRS is an LA County (county-wide) trunked system.
Radio checks on CRIS TG 1301. On the CWIRS side, it looked like they were borrowing a P&R tac…
marcotor
I ♥ÆS Ø
Sunny SoCal
Heard the CWRS references today, users seemed to be mainly in the Santa Clarita Valley from locations given. And several asked if they were heard on "the Harris radio".
mkewman
Sacramento County, California
It's interesting that you weren't able to pick up any sites from the Antelope Aquatic Center, one of the first locations I "played" with this system was in the parking lot of the Kohl's at Antelope and Don Julio. Pine Hill came in rather well from that location on my Unication and SDS100. I also drove around the Rio Linda area testing the range of a few sites and got fairly good results in that area.
I thought it was weird too. It might've been in the shadow of the school or something since I was down at the lower pool?
vince48
Central Valley, CA.
[QUOTE="tsalmrsystemtech, post: 3712661, member: 1380233"
Looks like CHP is on CRIS now and some talkgroups are Encrypted.
[/QUOTE]
Sir,
would you expand on your message as to "WHERE" your location is and "What" you are hearing?
tsalmrsystemtech
85935bDCHP BLUE 2CHP Blue 2 - BaseLaw Dispatch
86035cTECHP BLUE 2CHP Blue 2 - MobileLaw Dispatch
86135dDCHP GOLD 3CHP Gold 3 - BaseLaw Dispatch
86235eTECHP GOLD 3CHP Gold 3 - MobileLaw Dispatch
86335fDCHP BLACK 3CHP Black 3 - BaseLaw Dispatch
864360TECHP BLACK 3CHP Black 3 - MobileLaw Dispatch
865361DCHP GREEN 3CHP Green 3 - BaseLaw Dispatch
866362TECHP GREEN 3CHP Green 3 - MobileLaw Dispatch
867363DCHP WHITE 3CHP White 3 - BaseLaw Dispatch
868364TECHP WHITE 3CHP White 3 - MobileLaw Dispatch
869365DCHP BROWN 3CHP Brown 3 - BaseLaw Dispatch
870366TECHP BROWN 3CHP Brown 3 - MobileLaw Dispatch
Rev: 2.0.6620
Soledad, CA
I noticed these updates too, and some key questions come to mind:
  • Why would CHP run clear FDMA on the base TGs but encrypted TDMA for Mobile TGs?
  • How does the information supplier know the identity of encrypted TGs
  • Why would the CHP employ the base/mobile structure on a trunking network?
Hmmm are the mobiles coming out clear on the base? Or you just hear the dispatcher?
KG7PBS
Sacramento CA
OK let’s dive into this. From what it appears the dispatch channel which is the base channel will be FDMA clear. I suspect the dispatch channels remain active and in the clear for outside agencies to monitor not everyone will have an APX.
In conclusion the mobile channel which is TDMA and encrypted with AES-256 this would allow CHP to be in compliance with the DOJ mandate about confidential Personal information.
I personally think CHP is going to keep the original set up so officers won’t have a hard time adjusting to the new system by totally Redesigning it. K.I.S.S.
AM909
Radio/computer geek
SoCal
Looks like they've just patched these from all the low-band channels for the Valley Division, which makes sense as being where Com Div HQ is located, right? BLU2 is the division tac. BLK3, GRN3, and GLD3 are all the Sacto Center dispatch channels. WHT3 is Stockton Center. BRN3 is Chico Center. The only missing one is Chico Center's GRY2; any bets on it being 871 and 872?
scannerboy02
From my understanding the entire system is (was) supposed to be fully TDMA voice.
Just my personal thoughts, they will have one "primary" 'channel' in the clear and a second "tac" 'channel' encrypted to pass PII.
From what I have been told, the Kenwood radios are already setup with the base/mobile frequencies as a single 'channel' (RX on base frequency/TX on mobile frequency), they also have different alpha tags with a separate 'channel' for each area office, even if more than one area office is on the same frequency.
