California Radio Interoperable System (CRIS)
Oakland_Tower
S.F. Bay Area
I also just found Site 19 on 770.20625. It should be Sunol Ridge, if someone can confirm that too.
[/QUOTE]
From my post in Fremont I can hear a weak signal (NAC 9D9H) that could be coming from Sunol. I"m shielded by the hills so signals up there are noisy.
phipac
Radio & Scanner Enthusiast
Orange County, CA
Thanks. If anyone else has neighbor lists that aren't in the DB, let me know and I can add them.
Santiago Peak (1E) is reporting a neighbor site (36) that is not listed.
Neighbor Sites
SYSTEM:9D2[2514] NAC:9D0[2512] RFSS:01[1] SITE:1B[27] LRA:00[0] CHANNEL:1-1184 DOWNLINK:769406250 UPLINK:799406250 STATUS:[VALID INFORMATION, ACTIVE RFSS CONNECTION]
SYSTEM:9D2[2514] NAC:9D0[2512] RFSS:01[1] SITE:1D[29] LRA:00[0] CHANNEL:1-1274 DOWNLINK:769968750 UPLINK:799968750 STATUS:[VALID INFORMATION, ACTIVE RFSS CONNECTION]
SYSTEM:9D2[2514] NAC:9D0[2512] RFSS:01[1] SITE:36[54] LRA:00[0] CHANNEL:1-1274 DOWNLINK:769968750 UPLINK:799968750 STATUS:[VALID INFORMATION, ACTIVE RFSS CONNECTION]
officer_415
SF Bay Area
If folks can check for it (Site 54, control channel 769.96875) we can try to nail down the location so it can be added to the DB.
I've added it to the Wiki for now.
phipac
Orange County, CA
It's extremely strong here in Anaheim, almost the same signal strength as I am picking up Santiago. I'll try to track it down but it seems to saturate the basin.
FrensicPic
Los Angeles
From the Western SFV. VHF-high quarter wave ground plane at 20 feet. (old Radio Shack scanner antenna).
Oat and Lukens are the two sites I can normally receive.
inigo88
California DB Admin
San Diego, CA
Very interesting - it’s booming in northern San Diego county as well. Signal strength was within a couple DBm of known control channels on either Palomar Mountain or Mount Woodson. Both those sites seem too far south to be receivable in OC and the LA Basin though… are you guys able to receive either site?
Here’s an experiment. This won’t be an exact science due to transmit power, antenna gain, etc but are you able to receive either of these sites in Orange County? If so how do they compare to CRIS site 54?
  • Fisher Wireless DMR Connect Plus site 119-3: 451.9125 MHz (control channel)
  • MRA NEXEDGE site R31-14, Palomar Mountain: 451.0125 MHz (control channel)
  • MRA NEXEDGE site R31-15, Mt Woodson: 454.440625 MHz (control channel)
inigo88
California DB Admin
San Diego, CA
Be advised, it's the same control channel as Mt. Lukens (Site 29).
CRIS recycles the same 8 sets of frequencies throughout the state.
That solves that mystery - the San Diego sites shouldn’t be coming in in the San Fernando Valley.
kg6nlw
Railroad & Ham Radio Extrodinare
Sonoma Co., California
I Unitrunkered site 16 from Mt Tam this morning and updated the DB.
I took a trip through Santa Rosa, Rohnert Park and Petaluma and am confident that this is indeed Sonoma Mountain. My Channel activity window of frequencies lines up with what you put in the DB.
I even captured some registrations to the site as well!
Regards,
-Frank C.
phipac
Orange County, CA
Update: 99% sure BEE00 system 9D2 Site 1-054 is Mt Woodson.
Definitely seems likely.
Another neighbor popped up with Santiago today.
SYSTEM:9D2[2514] NAC:9D0[2512] RFSS:01[1] SITE:30[48] LRA:00[0] CHANNEL:1-1184 DOWNLINK:769406250 UPLINK:799406250 STATUS:[VALID INFORMATION, ACTIVE RFSS CONNECTION]
mcjones2013
Radio Communications Enthusiast
Sacramento, CA
Has anyone else noticed a significant reduction in output power on the control channel frequencies for the various sites this past week? I can usually receive 1, 2, 7, 8, 15, 18, 21, 23, 66 booming in southern Sacramento County, but no longer this week.
It seems like they've now linked the whole system together this past week (as seen with the neighbor sites changing), and I'm curious if they made changes to output power so there's no overlap in coverage.
officer_415
SF Bay Area
Keep an ear out for inland VHF sites in Alpine, Mono, and Inyo counties. There should be sites at Leviathan Peak, Sweetwater, Conway Summit, Crestview, and Silver Peak. Site 3 (Mt. Bullion) was broadcasting the following VHF neighbors today:
Site 63 - CC 151.2050
Site 64 - CC 151.0025
EDIT: Looks like these are Crestview and Sherwin Summit, based on FCC license info.
officer_415
SF Bay Area
Found the following inland VHF licenses:
WRPW349 - Leviathan Peak (Alpine County)
151.1975
151.4525
154.2425
155.1825
WRPH873 - Sweetwater (Mono County)
154.3175
154.8525
155.1525
155.3550
WROV267 - Conway Summit (Mono County)
151.1450
154.1825
154.8150
155.3250
WROV271 - Crestview (Mono County)
151.2050
154.2050
154.7625
155.1300
WROU856 - Sherwin Summit (Mono County)
151.0025
151.2350
151.4525
154.1675
WROY819 - Silver Peak (Inyo County)
154.3625
154.7475
155.2275
155.4525
