Calls run together
KSPILOT536
Park City,KS
How can I set my P25 so that there is a pause between calls..like a 2 second pause because the way I have it setup another call will come in before the dispatch or the the cop answers..not all the time but it happens a lot.
pro106import
Milford, Ct. perched high above Long Island Sound
In the "TG Editor" tab, down at the lower left is your delay time for talkgroups. Set it for at least 2 seconds and then hit the Write Config button on the bottom right of the same tab
FreqNout
Chicagoland
On the p25rx btconfig, try changing Talk Group Timeout. P25RX Config tab center of the screen. Write config to p25rx button is right below the TG Timeout selector box.
K9DAK
Wauconda, IL
Also, I found that you may have to adjust your "High DPI Settings" on certain PC/monitor combinations... I found some settings/buttons hidden until I made that adjustment.
