Chris0516
Just as the title says. I thought it was specific to Proscan, but. It is doing the same thing to Sentinel.
Do you get any error messages?Just as the title says. I thought it was specific to Proscan, but. It is doing the same thing to Sentinel.
I have already been doing that.
Both are in MSM. Proscan records the activity fine on both.Do you get any error messages?
Is the scanner in Mass Storage Mode?
Does the scanner show up in Device Manager?
Have you rebooted the computer?
They are in separate directories.I do this at least once a month. Are both instances sharing the same file?
Proscan is using the serial mode when recording activity. It is not accessing the SD cardBoth are in MSM. Proscan records the activity fine on both.
Both(individually) are in MSM, when. I try Read/Write from/to, the scanner. No change in Device Manager. Both show up.Proscan is using the serial mode when recording activity. It is not accessing the SD card
Does the scanner show up in Device Manager when in MSM?
They have always been in separate directories.Are both instances pointing to the same database file used for programming? When you made the second instance, how did you do that?
Did you follow these steps?
That error only appears on the SDS100. I have not scanned it, yet.Your post in the ProScan thread says you are getting a "scan the card" error message. Have you scanned the cards for errors?
I have had them in separate directories every time, there was a new upgrade to Proscan. It has worked for more than a year.Ok, but how did you set up the 2 instances? Did this work before?
Did it ever work in Proscan? Lets start there.
Might want to scan them both before proceeding, they maybe corrupted in some way.That error only appears on the SDS100. I have not scanned it, yet.
