Cb radio wont power on?
I have an 73 General Electric cb Mobile weather cb radio that won't power on. I have tested almost everything but protection diode. Does anyone know where the protection diode is?
KC2GIU
Typically, the protection diode can be found VERY CLOSE to where the power wires enter the radio chassis.
Due note, some manufactures didn't place over-voltage protection in their radios, thus the radio is fried.
What is a 73? Do you have a link or pix of it?
The reverse polarity protection diode should be the very first component in line with the red wire coming in the back of the radio.
Cut one leg of it and separate it, make sure you power polarity is correct and there is a proper amperage fuse in the power cable.
The radio should turn on if the diode was the problem. Replace it as necessary and make sure you put it in the same way the old one came out.
The model number is 3-5829B and the serial number is 001628. I tried looking for information on cbmods.com but I could find nothing about this radio anywhere.
Thanks everyone.
