Redwood Meadows Emergency Services is purchasing a new tender (water hauler) to replace the truck assembled by department members in the mid-1990s. Said truck, a 1986 Ford C8000 ex-garbage hauler from the City of Calgary, coupled with a 2500 imperial gallon Imperial Oil home oil heating tank and a 500 IGPM Hale pump in between, has reached the end of its useful life and safe operating condition.
The new truck is being built by Pierce Manufacturing, the same Bradenton, FL/Appleton, WI fire apparatus manufacturer which built the 2009 Kenworth Contender pumper received by Redwood Meadows in June 2009. The unit is being sold by WFR Wholesale Fire Rescue, the Calgary-based Western Canada dealer for Pierce Mfg.
The new 50 Tender is a Peterbilt 348 tandem-axle cab/chassis with a two-person cab; 3000 US gallon polypropylene water tank, 1000 USGPM (840 IGPM) Hale pump, and custom firefighting body painted Pierce red with NFPA-compliant lighting and reflective striping, including a full rear face application of chevron striping. The truck is powered by a PACCAR PX-8 380hp diesel engine and a 5 speed automatic Allison electronic pushbutton transmission. It will have electric-hydraulic racks mounted on both sides to fit portable collapsing "drop tanks" (which are used in tanker/tender shuttles to dump the load of water for use at a fire scene, so the water can be used at-scene while the truck goes to refill). An Arrow Stick type directional warning device will be installed on the rear of the truck for use as a Scene Safety Vehicle.
As with all Redwood Meadows apparatus, this vehicle will have radios installed for all three local fire/emergency services bands (UHF conventional, VHF conventional, and 700/800 trunking for both Calgary DRS and the upcoming AFRRCS).
Delivery is expected before spring.
Here are some photos courtesy of Pierce Manufacturing, Bradenton, FL:
