CHIRP radio programming software ??
merlin
DN32su
Anybody know Chirp well enough to say what and where the configuration file is ?
Starts and runs on my Win 10 machine but I need it on my XP bench machine where I get error "CHIRP application failed to start because the configuration is incorrect."
Can't get help on CHIRP website as it won't let me log in and no direct contact link.
73s
nd5y
Wichita Falls, TX
Search for a file named chirp.config.
I don't know the location it would be in on a Windows system. It should be somewhere in your username folder.
nosig55
I get "application configuration is incorrect" when I try to run CHIRP
The full error message as seen by the user is: "Application cannot run because application configuration is incorrect"
This is a problem with your Windows XP machine and its standard libraries. Most users seem to be able to resolve this issue by downloading the Microsoft Visual C++ 2008 SP1 Redistributable Package.
merlin
DN32su
I am thinking it is the lack of the 2008 dot net runtime, that is what I am looking into now but was sure I have that on the XP machine.
List all my dot net versions it fills a page.
TNX
merlin
DN32su
No such animal on the machine. Chirp SW dot XXX files are like nothing you have seen save for dot DLL.
IE: PYD, XSD. SH, and such.
K9RPL
Western Burb's of Chicago
Actually there is a chirp.config. It's in the C:/Users/username/Appdata/Roaming/CHIRP folder. It's hidden though and not much in it. Just some saved info like Radio, Commport, last file edited, bandplan, columns etc.
merlin
DN32su
This is on an XP machine so such directory doesn't exist. that is my bench computer for radio programming and JTAGing.
Might be forced to build up an FTDI USB interface on the Win10 machine.
73s
K9RPL
73s
Wow, Old School... I doubt Chirp treats XP any different and there's probably a chirp.config sitting in a hidden folder.
Good luck though..
9Track
The equivalent location in XP is:
C:\Documents and Settings\<username>\Application Data\CHIRP
You may have to enable showing invisible files.
merlin
DN32su
Hence my problem, there is no "Chirp" folder in this directory, and yes, I show all files and folders.
merlin
DN32su
This problem has been solved with the installation of V4 dot net framework/runtime. The config file is in the documents foler containing a CHIRP folder.
This runs just fine, but no provisions for this commercial radio stuff.
