SDRTrunk SDRTrunk Won't Launch
jared2295
Texas
I've had SDRTrunk on this machine before, but lost everything during a backup, so I'm trying to reinstall. When I run sdr-trunk.bat, CMD will open and run through the normal processes, but never opens the application. It'll show the little SDRTrunk icon on the bottom of the taskbar, but it wont open onto the screen. Any ideas why the application won't launch?
Here's what CMD shows :
WARNING: Using incubator modules: jdk.incubator.vector
2025-08-11 18:22:57.892 INFO i.g.d.p.SystemProperties - Creating application root folder: C:\Users\jared\SDRTrunk [17MB/768MB 2%]
2025-08-11 18:22:57.908 INFO i.g.d.icon.IconModel - loading icons file [C:\Users\jared\SDRTrunk\settings\icons.xml] [18MB/768MB 2%]
2025-08-11 18:22:57.908 INFO i.g.d.icon.IconModel - Icons file not found at [C:\Users\jared\SDRTrunk\settings\icons.xml] [18MB/768MB 2%]
2025-08-11 18:22:58.205 INFO i.g.d.p.d.DirectoryPreference - Created directory [C:\Users\jared\SDRTrunk\logs] [26MB/768MB 3%]
2025-08-11 18:22:58.205 INFO i.g.d.log.ApplicationLog - Application Log File: C:\Users\jared\SDRTrunk\logs\sdrtrunk_app.log [26MB/768MB 3%]
2025-08-11 18:22:58.236 INFO i.g.d.log.ApplicationLog - SDRTrunk Version : 0.6.1 [29MB/768MB 3%]
2025-08-11 18:22:58.236 INFO i.g.d.log.ApplicationLog - Gradle Version : Gradle 8.10 [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - Build Timestamp : 2024-12-03T16:29:36.848-0500 [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - Build-JDK : 23 (BellSoft 23+38 [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - Build OS : Linux (amd64 6.8.0-49-generic [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - ******************************************************************* [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - **** sdrtrunk: a trunked radio and digital decoding application *** [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - **** website: GitHub - DSheirer/sdrtrunk: A cross-platform java application for decoding, monitoring, recording and streaming trunked mobile and related radio protocols using Software Defined Radios (SDR). Website: *** [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - Memory Logging Format: [Used/Allocated PercentUsed%] [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - Host OS Name: Windows 10 [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - Host OS Arch: amd64 [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - Host OS Version: 10.0 [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - Host CPU Cores: 16 [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - Host Max Java Memory: 11 GB [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - Storage Directories: [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - Application Root: C:\Users\jared\SDRTrunk [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - Application Log: C:\Users\jared\SDRTrunk\logs [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.p.d.DirectoryPreference - Created directory [C:\Users\jared\SDRTrunk\event_logs] [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - Event Log: C:\Users\jared\SDRTrunk\event_logs [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.p.d.DirectoryPreference - Created directory [C:\Users\jared\SDRTrunk\playlist] [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - Playlist: C:\Users\jared\SDRTrunk\playlist [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.p.d.DirectoryPreference - Created directory [C:\Users\jared\SDRTrunk\recordings] [29MB/768MB 3%]
2025-08-11 18:22:58.252 INFO i.g.d.log.ApplicationLog - Recordings: C:\Users\jared\SDRTrunk\recordings [29MB/768MB 3%]
2025-08-11 18:22:58.283 INFO i.g.d.s.t.s.a.SDRPlayLibraryHelper - SDRPlay API native library not found at: C:\Program Files\SDRplay\API\x64\sdrplay_api [7MB/32MB 22%]
2025-08-11 18:22:58.283 INFO i.g.d.util.ThreadPool - Application thread pool created SCHEDULED and CACHED executors threads [7MB/32MB 23%]
2025-08-11 18:22:58.283 INFO i.g.dsheirer.gui.SDRTrunk - SDRTrunk - creating application properties file [C:\Users\jared\SDRTrunk\SDRTrunk.properties] [7MB/32MB 23%]
2025-08-11 18:22:58.283 INFO i.g.d.p.SystemProperties - SystemProperties - loaded [C:\Users\jared\SDRTrunk\SDRTrunk.properties] [7MB/32MB 23%]
2025-08-11 18:22:58.330 INFO i.g.d.p.d.DirectoryPreference - Created directory [C:\Users\jared\SDRTrunk\configuration] [8MB/32MB 26%]
2025-08-11 18:22:58.330 INFO i.g.d.s.t.m.TunerManager - Discovering tuners ... [8MB/32MB 26%]
2025-08-11 18:22:58.423 INFO i.g.d.s.t.m.TunerManager - LibUsb API Version: 1.0.262 [9MB/32MB 30%]
2025-08-11 18:22:58.423 INFO i.g.d.s.t.m.TunerManager - LibUsb Version: 1.0.22.11312 [9MB/32MB 30%]
2025-08-11 18:22:58.439 INFO i.g.d.s.t.m.TunerManager - LibUsb - discovered [17] potential usb devices [9MB/32MB 30%]
2025-08-11 18:22:58.455 INFO i.g.d.s.t.m.TunerManager - Discovered tuner at USB Bus [1] Port [2.2] Tuner Class [RTL-2832] [10MB/32MB 32%]
2025-08-11 18:22:58.455 INFO i.g.d.s.t.m.TunerManager - Discovered tuner at USB Bus [1] Port [3.1] Tuner Class [RTL-2832] [10MB/32MB 32%]
2025-08-11 18:22:58.455 INFO i.g.d.s.t.m.TunerManager - Discovered tuner at USB Bus [1] Port [3.4] Tuner Class [RTL-2832] [10MB/32MB 32%]
2025-08-11 18:22:58.455 INFO i.g.d.s.t.m.TunerManager - Discovered tuner at USB Bus [1] Port [1.4] Tuner Class [RTL-2832] [10MB/32MB 32%]
2025-08-11 18:22:58.455 INFO i.g.d.s.t.m.TunerManager - Discovered tuner at USB Bus [1] Port [1.1] Tuner Class [RTL-2832] [10MB/32MB 32%]
2025-08-11 18:22:58.455 INFO i.g.d.s.t.m.TunerManager - Tuner: USB Tuner - RTL-2832 USB Bus:1 Port:2.2 - Added / Starting ... [10MB/32MB 32%]
2025-08-11 18:22:59.517 INFO i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [2400000.0] providing [96] channels at [25000.0] Hz each [15MB/32MB 47%]
2025-08-11 18:22:59.658 INFO i.g.d.s.t.m.TunerManager - Tuner: USB Tuner - RTL-2832 USB Bus:1 Port:3.1 - Added / Starting ... [15MB/32MB 48%]
2025-08-11 18:23:00.658 INFO i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [2400000.0] providing [96] channels at [25000.0] Hz each [15MB/32MB 48%]
2025-08-11 18:23:00.783 INFO i.g.d.s.t.m.TunerManager - Tuner: USB Tuner - RTL-2832 USB Bus:1 Port:3.4 - Added / Starting ... [15MB/32MB 49%]
2025-08-11 18:23:01.845 INFO i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [2400000.0] providing [96] channels at [25000.0] Hz each [29MB/32MB 92%]
2025-08-11 18:23:01.970 INFO i.g.d.s.t.m.TunerManager - Tuner: USB Tuner - RTL-2832 USB Bus:1 Port:1.4 - Added / Starting ... [7MB/48MB 16%]
2025-08-11 18:23:03.033 INFO i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [2400000.0] providing [96] channels at [25000.0] Hz each [8MB/48MB 17%]
2025-08-11 18:23:03.173 INFO i.g.d.s.t.m.TunerManager - Tuner: USB Tuner - RTL-2832 USB Bus:1 Port:1.1 - Added / Starting ... [8MB/48MB 17%]
2025-08-11 18:23:04.236 INFO i.g.d.d.f.c.ComplexPolyphaseChannelizerM2 - Sample Rate [2400000.0] providing [96] channels at [25000.0] Hz each [8MB/48MB 18%]
2025-08-11 18:23:04.362 INFO i.g.d.s.t.m.TunerManager - LibUsb Hotplug event notification Is Not Supported on this platform. [8MB/48MB 18%]
2025-08-11 18:23:04.362 INFO i.g.d.s.t.s.api.SDRplay - API library is not available - unsupported version: 0.0 [8MB/48MB 18%]
2025-08-11 18:23:04.362 INFO i.g.d.s.SettingsManager - SettingsManager - settings does not exist [C:\Users\jared\SDRTrunk\settings\settings.xml] [9MB/48MB 19%]
2025-08-11 18:23:04.393 INFO i.g.d.m.DiagnosticMonitor - Diagnostic monitoring enabled running every 30 seconds [10MB/48MB 21%]
2025-08-11 18:23:04.630 WARN i.g.d.v.VectorUtilities - CPU supports maximum SIMD instructions of Species[float, 8, S_256_BIT] [16MB/48MB 34%]
2025-08-11 18:23:05.176 INFO i.g.d.p.PlaylistManager - PlaylistManager - playlist not found at [C:\Users\jared\SDRTrunk\playlist\default.xml] - creating new (empty) playlist [23MB/48MB 49%]
2025-08-11 18:23:05.177 INFO i.g.dsheirer.gui.SDRTrunk - starting main application gui [23MB/48MB 49%]
PDXh0b0
Woodland, WA
"It'll show the little SDRTrunk icon on the bottom of the taskbar, but it wont open onto the screen."
If you hoover your mouse over that sdrtrunk icon does a view of the opened sdrtrunk show? If so, right click it and choose maximize 20250811_171656.jpg
jared2295
Texas
When I hover over the icon, it just shows a blank white square. And clicking maximize does nothing. I can post a screenshot if needed.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
What kind of hardware you running it on? Do you have the waterfall turned on. If you are running it on gutless hardware (many try), and especially if you have the waterfall turned on, then you could be maxxing out CPU and may not have enough resources to run it.
jared2295
Texas
Running Windows Home 10
Processor AMD Ryzen 7 2700X Eight-Core Processor 3.70 GHz
Installed RAM 48.0 GB
Storage 224 GB SSD WDC WDS240G2G0A-00JH30, 1.82 TB HDD ST2000DM006-2DM164
Graphics Card NVIDIA GeForce RTX 2070 (8 GB)
System Type 64-bit operating system, x64-based processor
What about clicking restore?
If I right click the SDRTrunk icon, the only option I get is "Close Window".
If I ALT/TAB to see all open window, it'll show a blank white screen for SDRTrunk. Nothing happens if I click on that window either...it just disappears back into the background somewhere.
Could it be off the screen? Were you running two monitors at any point?
Yes, I did have 2 monitors previously, but only one now.
PDXh0b0
Woodland, WA
What happens if you hoover the mouse over the icon in task bar, right click, click restore or maximize, hoover, right click , click move, push left or right arrow key on keyboard, then moved your mouse left or right....does the sdrtrunk come onto the screen?
jared2295
Texas
I hovered over the icon, moved the cursor up onto the blank white preview box, THEN right clicked on that box, at which point it gave me the option to maximize.....and it popped right up. Problem is solved, everything seems to be working now. Thank you for your help!
PDXh0b0
Woodland, WA
Right on. Once all setup, I copy the C:/users/username/sdrtrunk folder to a thumb drive as a backup. That folder with work with new sdrtrunk installs
frazpo
SW Mo
No problem. In the future bring your windows to your main screen before shutting down. This should help bring the windows back up on your main screen in the case your second screen isnt available for some reason.
Seymour, TN
Did you by any chance get a Windows 24H2 update? That's what killed mine and I can't find the cure!!
