Yes, each channel is provisioned as P25 and both slots.Can anyone confirm if the Collier P25 system is exclusively phase 2?
The DB shows a mix of Phase 1 and 2.
RFSS | Site | Name | Freqs | |||||||
10 (A) | 010 (A) | Naples Simulcast | 854.3625c | 856.4375c | 856.4875c | 856.9375c | 856.9625c | 857.4875c | 857.9625c | 858.9375c |
858.9625c | 859.4875c | 860.4375c | 860.7625c |
I would suggest start by reviewing the 4 settings for the system as depicted below.
@ACKStatic Make sure you put in the site number as hex not decimal. The picture I posted is correct. The value of 10 is decimal not Hex. 10 will not work. I made that mistake when I first programmed the G5.RFSS should be 10 Not A , Site should be 010 Not A. All the control channels must be programed.
RFSS Site Name Freqs 10 (A) 010 (A) Naples Simulcast 854.3625c 856.4375c 856.4875c 856.9375c 856.9625c 857.4875c 857.9625c 858.9375c 858.9625c 859.4875c 860.4375c 860.7625c
System is still on the air with a strong control channel. However, not a single voice transmission on the system after 7 days of continuous monitoring. Info submitted to DB.can someone confirm that the old EDACS system in Collier is OTA? Please submit to the RR Db so this can be corrected if necessary.
Collier County (EDACS) Trunking System, Collier County, Florida
Collier County (EDACS) Trunking System Profilewww.radioreference.com
