Comal & Hays Emergency Services
garys
Central Texas
I don't get down as far as New Braufels all that often, but when I have I've received the Comal County system very well.
Noted. Kyle is a bit out of my area of interest. I’ve been able to program Hays conventional channels but no test drive yet. NBFD dispatch is hitting often while in NB
Cfhebertjr
New Braunfels
Here's your file as modified, if you want to try it.
I marked as "locked out" the Hays County TGIDs that are either full time encrypted, or P25 Phase II. I did leave TGID 11001 (New Braunfels PD dispatch) unlocked; it is P25 Phase I, and only marked as part time encrypted. When they are in the clear, you'd hear them. If encrypted, you'll hear garbled audio, sometimes described (in the forums) as R2D2 on steroids. I left those on your Scanlist 2
I added the public safety TGIDs for Comal, on GATRRS, that are not encrypted. All of the GATRRS talkgroups are P25 Phase I, so if you can hear the site(s), you'd hear activity. Obviously. if not of interest, either delete the GATRRS trunked system or lock it out. Those are enabled on Scanlist 4. I did not import GATRRS talkgroups marked as full time encrypted.
I did not alter what you had imported for conventional channels. You'll likely want to weed out a few of those, for example the water department. You had those assigned to Scanlist 3, but it was not enabled to scan; only Scanlist 2. LCRA. I enabled the conventionals.
Instead of seeing "Scanlist 2" (or 3, or 4) scroll across the bottom of your display, you can name the lists, such as LCRA for Scanlist 2. And, if you want, you can tag your conventional channels, as well as talkgroups, to use the LED display, such as Red for Fire talkgroups, Blue for Police. I use Red for Fire, Yellow for EMS, the light blue (Uniden labels it as Cyan) for city PDs, and the dark blue for state law enforcement (Tx DPS). You can also select any of them to flash, if you want to spot your more important channels when in use. Whether you do that or not is completely up to you.
You do not have Tx DPS talkgroups on LCRA imported, so I did not import them into GATRRS either. DPS does have some conventional frequencies, but I have no idea how much they are used in your counties of interest. They might use only the trunked systems. Whether you add their talkgroups, and/or conventional channels is up to you.
The file is zipped. Use Windows Explorer to unzip and then open in Win500 to take a peek.
I'm throwing darts. Doing my best to understand all this but not successful. I downloaded the scan list 02a file but can only see it on my desktop screen. cant find it's path to import it. It does not appear in downloads. unable to import the file into scanner. i attempted to program the GATRRS system into scan list 06. nothing but silence. i see no channels listed i understand tagging the channels and led modes but that's a 'down the road' item. i will visit my pc geek son tomorrow and see if he can put me in the right direction.
I cannot find this "multi-site table you posted.
garys
Central Texas
Click on the down arrow next to stationary and you should see a list for multi-site as a choice.
To download the zip file click on it and a list of options including "download file." Once it's downloaded you'll have to find the folder it downloaded into. Usually that the "download" file, but that's not always it.
hiegtx
Mentor
Dallas, TX
As garys has already noted, the file I posted is zipped. If you can see it on your desktop screen, then it did download.
In Edge (the current name for what used to be called Internet Explorer, click on the three dots next to your avatar symbol.
With that dialog box displayed, click on Downloads.
That will give you a list of files downloaded. If you'll hover your mouse over the the file, you'll see a file folder icon beside the file name. CLick on that folder to see where on your PC the file landed when downloaded.
I zipped the file since *.p500 is not a valid file extension to attach to a forum post. Once you confirm where it was downloaded, you can <right><click> on the file to get the option to "Extract" (un-zip) the compressed file to the original file extension, which you can then import into Win500 and see it, and/oor load it to your scanner.
Here's a new link to the file in my One drive folder. That is not zipped. You should be able to open and import it into the Win500 software.
hiegtx
Mentor
Dallas, TX
That's on the TSYS Objects tab.
On your original file, you had it set as "Roam".
Set as "Roam", the scanner would look, and only use the control channel frequency with the best signal. Since the frequencies for several sites are loaded, you'd only hear traffic for that one site. For example, if it grabbed & used the control channel for the New Braunfels site, all you'd likely get would be NB talkgroups. You'd miss transmissions of other city or county users that were on one of the other sites, not the one assigned for New Braunfels.
I set the MultiSite mode to Stationary, and checked the box to check all the Control Channels loaded each time the system was scanned. If it was set as Stationary, but the box was not checked, it would check the control channel for the first set of site frequencies on the first pass through the system.
On the next pass, it would look for the (different) control channel of the second site.
On the third pass, it would look at frequencies for the third site.
Once it had checked all control channels found, it would go back and start the cycle again, checking for the first site once more. That pattern repeats itself, cycling through the sets of control channels, one at a time. By checking the box, you're telling the scanner to use any sites control channel traffic each time the system comes up in the scan rotation.
Cfhebertjr
New Braunfels
this is what i get when i find the file.
when i select the zipped file a text file appears
the unzipped file looks like this. once i am in win500 i cannot find the file from import. i know where it is but win500 is not seeing it.
Cfhebertjr
New Braunfels
okay i fixed that bit
hiegtx
Mentor
Dallas, TX
That view looks like it's still looking at the compressed file (that's the one highlighted in your post; out to the side it says "zipped".
Use the second link I posted. That file is not zipped, and once saved to your PC, you should be able to import it into Win500.
(To reduce 'confusion',delete the file that is zipped.)
Cfhebertjr
New Braunfels
Not sure if this message will reach you. On sign in a message says my IP has been banned and I can’t sign in to view support messages. No idea what has happened
Cfhebertjr
New Braunfels
It appears messages are going through. I was not able to upload the file so I’ve moved on. DL’d arc500. I was able to upload the GATRRS sites and TG I want. Now Comal SO patrol is hitting. Uploaded a few more sites,TG and conventional analog frequencies from CBP, DPS, ATF, etc. I anticipate that I will move forward by trial and error. Many thanks for the input so far. I wouldn’t mind taking a CE course on radio basics. My dad had a ham unit back in the day. I also volunteered as dispatcher in Harris County 45 years ago. LEO for HCCO Pct 4 patrol afterwards
hiegtx
Mentor
Dallas, TX
That's likely a "false positive" error message. What are you clicking on when that message comes up? The link for the file I posted to my One Drive account? Or something different.
You should have been able to access the file in my One drive. You were able to post yours in One Drive, and there's no difference in your, or mine, One Drive account, other than the details specific to the user.
The posted file (in One Drive) is exactly the same as the one I posted several posts back. If you unzip it, it can be opened in Win500.
You should be able to access the "Conversations" link at the top of the page. It's the icon that looks like an envelope, just to the right of your user name for the Forums.
You can start a conversation, using my forum ID, hiegtx, as the recipient. Give me your email address, & then I can then mail you a copy of whatever I send you without having to zip it.
