Connect+ and DSD+FL
kg6nlw
Railroad & Ham Radio Extrodinare
Sonoma Co., California
I've had wonderful luck listening to a local Connect+ DMR system. Lately, I'd say the last 72 hours, I have no longer been able to receive any audio from the system. I have checked over the settings and NOTHING has been changed. I reset all files to default settings, thinking perhaps it's the *.frequencies or *.Sites/*.SiteLoader files but that did not help. I even tried piping the audio from SDR# into DSD+FL instead of using my usual DSD+/FMP combo.
Does anyone have any ideas as to what's wrong? I've even had a few DSD+ buddies remote in and look with no luck.
Regards,
-Frank C.
Kazzaw
South East QLD, Australia
Can you receive other systems? Weird for it to suddenly stop working, especially if you have rebooted your system.
Are you seeing activity through DSDPlus
kg6nlw
Yes I am able to receive other types of systems but not Connect+ for some reason. Yes, I have rebooted it several times. I still see everything in DSD+ and the Console windows are operating normally too.
Regards,
-Frank C.
kg6nlw
I rebooted again and now SDR#/DSD+ combo is letting me hear traffic but DSD+/FMP IS NOT.
Regards,
-Frank C.
cg
Connecticut
verify you haven't inadvertently hit a key shutting off a feature or function. If DSDPlus works with SDR sharp, the issue would be in FMPx or it's settings.
kg6nlw
Any suggestions on where to start looking? ALL menu items in DSD+ are in the places they should be like "No Source Audio Monitoring" so I don't hear the digital hash, Synthesize all Digital Voice is selected, etc.
Regards,
-Frank C.
kg6nlw
Hopefully this fits. My DSDPlus.frequencies file.
DMR, 0, 1, 0, 859.8625, 0.0, 0
NXDN48, 1, 1, 0, 160.2525, 0.0, 0
NXDN48, 1, 1, 0, 160.3050, 0.0, 0
NXDN48, 1, 1, 0, 160.4325, 0.0, 0
NXDN48, 80, 14, 0, 460.80000, 0.0, 0
NXDN48, 80, 14, 0, 461.55000, 0.0, 0
NXDN48, 80, 14, 0, 461.75000, 0.0, 0
NXDN48, 80, 14, 0, 461.85000, 0.0, 0
NXDN48, 80, 16, 0, 460.65000, 0.0, 0
NXDN48, 80, 16, 0, 460.72500, 0.0, 0
NXDN48, 80, 16, 0, 460.87500, 0.0, 0
NXDN48, 80, 16, 0, 464.90000, 0.0, 0
NXDN48, 80, 17, 0, 460.82500, 0.0, 0
NXDN48, 80, 17, 0, 460.67500, 0.0, 0
NXDN48, 80, 17, 0, 462.53750, 0.0, 0
NXDN48, 80, 17, 0, 462.73750, 0.0, 0
NXDN48, 80, 17, 0, 463.95000, 0.0, 0
NXDN48, 80, 40, 0, 460.66875, 0.0, 0
NEXEDGE48, 1, 12, 0, 463.35000, 0.0, 0
NEXEDGE48, 1, 12, 0, 461.67500, 0.0, 0
NEXEDGE48, 1, 10, 0, 454.00000, 0.0, 0
NEXEDGE48, 1, 10, 0, 463.48750, 0.0, 0
NEXEDGE48, 1, 10, 0, 463.63750, 0.0, 0
NEXEDGE48, 1, 10, 0, 463.97500, 0.0, 0
NEXEDGE48, 1, 10, 0, 461.43750, 0.0, 0
Con+, 119, 49, 0, 451.7000, 0.0, 0
Con+, 119, 49, 27, 452.4000, 0.0, 0
Con+, 119, 49, 0, 456.7000, 0.0, 0
Con+, 119, 49, 0, 457.4000, 0.0, 0
Con+, 119, 49, 0, 461.9250, 0.0, 0
Con+, 119, 49, 0, 462.0750, 0.0, 0
Con+, 119, 49, 0, 462.1750, 0.0, 0
Con+, 119, 49, 0, 463.3250, 0.0, 0
Con+, 119, 49, 0, 463.6500, 0.0, 0
Con+, 119, 49, 0, 463.9250, 0.0, 0
Con+, 119, 49, 0, 464.2750, 0.0, 0
Con+, 119, 34, 0, 452.85000, 0.0, 0
Con+, 119, 34, 0, 454.25625, 0.0, 0
Con+, 119, 34, 0, 464.57500, 0.0, 0
Con+, 119, 35, 0, 463.88750, 0.0, 0
Con+, 119, 35, 0, 490.73750, 0.0, 0
Con+, 119, 35, 0, 483.83750, 0.0, 0
Con+, 119, 50, 0, 454.34375, 0.0, 0
Con+, 119, 50, 0, 454.38750, 0.0, 0
Con+, 119, 50, 0, 463.96250, 0.0, 0
Con+, 119, 50, 0, 452.38750, 0.0, 0
Con+, 119, 50, 0, 464.85000, 0.0, 0
Con+, 119, 51, 0, 454.35625, 0.0, 0
Con+, 119, 51, 0, 461.65000, 0.0, 0
Con+, 119, 51, 0, 464.57500, 0.0, 0
Con+, 119, 51, 0, 464.82500, 0.0, 0
Con+, 119, 53, 0, 451.09375, 0.0, 0
Con+, 119, 53, 0, 452.05000, 0.0, 0
Con+, 119, 53, 0, 463.50000, 0.0, 0
Con+, 119, 53, 0, 462.37500, 0.0, 0
dPMR, 7239, 1, 0, 488.700000, 0.0, 0
dPMR, 7239, 1, 0, 489.075000, 0.0, 0
dPMR, 7239, 1, 0, 483.025000, 0.0, 0
dPMR, 7239, 1, 0, 483.125000, 0.0, 0
dPMR, 7239, 1, 0, 482.350000, 0.0, 0
dPMR, 7239, 1, 0, 482.625000, 0.0, 0
dPMR, 7239, 1, 0, 482.650000, 0.0, 0
dPMR, 7239, 1, 0, 482.787500, 0.0, 0
dPMR, 7239, 1, 0, 482.937500, 0.0, 0
dPMR, 7239, 1, 0, 489.912500, 0.0, 0
dPMR, 7239, 1, 0, 490.937500, 0.0, 0
dPMR, 7239, 2, 0, 488.850000, 0.0, 0
dPMR, 7239, 2, 0, 489.100000, 0.0, 0
dPMR, 7239, 2, 0, 483.150000, 0.0, 0
dPMR, 7239, 2, 0, 488.425000, 0.0, 0
dPMR, 7239, 2, 0, 482.975000, 0.0, 0
dPMR, 7239, 2, 0, 483.050000, 0.0, 0
dPMR, 7239, 2, 0, 483.512500, 0.0, 0
dPMR, 7239, 3, 0, 488.700000, 0.0, 0
dPMR, 7239, 3, 0, 482.325000, 0.0, 0
dPMR, 7239, 3, 0, 483.537500, 0.0, 0
dPMR, 7239, 4, 0, 490.100000, 0.0, 0
dPMR, 7239, 4, 0, 489.325000, 0.0, 0
dPMR, 7239, 4, 0, 489.700000, 0.0, 0
dPMR, 7239, 4, 0, 490.725000, 0.0, 0
dPMR, 7239, 4, 0, 488.975000, 0.0, 0
dPMR, 7239, 5, 0, 489.450000, 0.0, 0
dPMR, 7239, 5, 0, 483.950000, 0.0, 0
dPMR, 7239, 5, 0, 488.475000, 0.0, 0
dPMR, 7239, 5, 0, 490.800000, 0.0, 0
dPMR, 7239, 5, 0, 483.025000, 0.0, 0
Regards,
-Frank C.
kg6nlw
And all but one of those entries have zero where the actual channel number belongs.
DSD+ has no clue what to tune to to follow voice calls.
Using the Con+ site I am having issues with, is it the BOLD or UNDERLINED number I need to change? I had a buddy help me and he said the "other frequency" should be 0 so that things can be followed...
Regards,
-Frank C.
slicerwizard
Toronto, Ontario
You need to fix the bolded parts:
kg6nlw
@slicerwizard; replacing all the bold numbers you highlighted with frequencies gave me a TON of errors...Reading the "how to use" I don't have actual OverTheAir Numbers as to which channel goes where...
Regards,
-Frank C.
slicerwizard
Toronto, Ontario
Because OTA channel numbers go there.
Well, if it all was working before, you must've had them. Where's your old .frequencies file? You make and keep some backups, yes?
