IC-R15 - First Impressions
vagrant
ker-muhj-uhn
California
I bought an Icom IC-705 just to monitor VHF air. The RC-15 has an edge over the IC-705 in every aspect...I do know the IC-705 is a Ham transceiver, but does have impressive performance on VHF air.
Did you compare the two using the same antenna?
xms3200
Cleveland, Ohio
Yes, using the same external Taco D-5076 antenna, the IC-705 was very impressive. The IC-R15 has a faster scan speed…. indoors, the IC-705 was picking up some noise with the Smiley ducky. I am still playing with the filters and other settings, I will update as I find new tweaks.
I can see the IC-R15 being the new “Gold Standard” for VHF air, it does not miss much on VHF.
CqDx
US
Hi all,
I have been seriously considering the IC-R15 as my primary VHF / Airband receiver, I was wondering what is the general opinion regarding UHF Airband reception and the recording feature of the radio.
thanks in advance !
bcradio
Victoria BC
Hi all,
thanks in advance !
UHF rocks! I am listening to a lot of UHF Milair and this radio is the best of all that I own. I have a BCD436 and 536, plus Icom IC-R2 and it is great. Recording works great, too.
bcradio
Victoria BC
@xms3200 I did buy the VHF Air Icom antenna, but found that the UHF reception was better with the stock duck it came with. For VHF air, that VHF antenna is much better.
Kiniutech
Past login as: questnz
Somwhere in the South Pacific
Hi, I tested Diamond RH 771, Watson WS881 , Watson WS901 ( suppose to be air band tuned antenna) and YAESU air receiver stock antenna on Uniden 125. Yaesu antenna beat them all For signal strength and clarity of reception. I would expect iCom FA-S270c air receiver antenna will perform the same on UHF air. Now Yaesu antenna
is permanently attached to Uniden 125 for air scanning , Whistler Trx-1 and iCom IC-R30 used for general scanning
CqDx
US
So I did pick up the IC-R15 last week and had been using it for listening to VHF and Airbands primiarly. Very impressed by it's sensitivity and able to pick up Airband transmissions indoor using the stock antenna. The scan speed is also amazing.
I haven't yet to figure out the bank structure. I have about 30 groups programmed but somehow a portion of them (ie. Group 1 - LGA TRACON and Group 3 - EWR TRACON) are in VFO-A and some are in VFO-B (ie. Group 2 - JFK TRACON).
bcradio
Victoria BC
It sounds like you have the same group checked in different Group Links, maybe...
In the menu structure, go Set>Scan>Group Link. There look at your each group link 1-3. See if any groups two groups have the same check box.
And to confirm, when you are scanning, VFO A is scanning one Group Link and VFO B is scanning a different one?
CqDx
US
Yep ,the Group Link is the one that is throwing my logic off. I was able to uncheck the box so now it is scanning the specific banks that I need independently.
Xray
Ima gonna hold out and see if there are any black friday sales [not holding my breath], if not I'll wait until spring before the airshow season, currently don't have much of a need for air in winter. Almost pulled the trigger on an ebay IC-R30 but I think that is too much scanner for me, haven't been into shortwave in years and my sd-100 & 200 have digital covered. Heard the screen is much better on the 15, faster and I like the concept of streaming the audio via bluetooth if it works out like I am thinking.
xms3200
Cleveland, Ohio
I noticed the difference in sensitivity between the IC-8600 & IC-R15, is lower the value the more sensitive the receiver?
