Coweta county newnan ga going to 700 mhz
Ctaylor1016
Coweta county going to this. What will this mean for me as a listener? I use a pro95 scanner, will I be able to listen or no with this scanner?
terrister
Ga
They will join the WARRS system which is a P25 digital setup. They will run in the 700Mhz range unlike the other Warrs partners running in the 800Mhz.
Sounds like time for a new scanner.
Ctaylor1016
So you're sure pro95 won't work?
What model do I need to be able to listen once they make the switch to 700mhz?
