CP200 Analog - PL Code Programming Issue
surgento1220
Hello,
I am running into some issues when programming my CP200's. I have 8 frequencies licensed with the FCC and want to take full advantage of the 16 channels on the radios. I have programmed separate CTCSS tones, but I seem to be walking over the channel that has the same frequency (despite it having a different tone). I was talking with a friend and he could not figure out why this would be happening. Any insight would be greatly appreciated!
I've included screenshots from CPS as well.
Thank you!
K2NEC
5F6
The PL tone is nothing more than a way to prevent interference or having to hear unwanted transmissions on your channel. If you remove the PL and leave the radio in CSQ, all transmissions, including ones with PL tones, will be heard. So you can put a PL on for transmit and receive but someone on CSQ will still hear everything and chances are you might be stepping on someone if it's a busy channel. It's really more suited for repeaters.
alcahuete
Southern California
It doesn't work that way. There are still two transmissions taking place on the same frequency, tone or not, and it's going to cause a ton of interference. The only way around this is to use Mototrbo so that two timeslots can be in use on the same frequency. You can't do that on non-D model 200s, and probably not without modifying your license.
