Crawford County Sheriff
stevenp1
ohio
does anyone know if Crawford county sheriff switched to a digital channel or system? old 154.86 channel seems dead and on their scanner feed on here it is active and digital but not on the old channel.
stevenp1
ohio
ok I have a 536hp but the dmr system in that county in the database has no sheriff listing
wa8pyr
Lead Database Admin
Ohio
System added
All,
This DMR system has been added to the Crawford County listing. Please submit any talkgroups you locate.
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
All,
TGID 1 Jail
TGID 2 Sheriff Dispatch.
J
Sent from my Moto G (4) using Tapatalk
wa8pyr
Lead Database Admin
Ohio
TGID 1 Jail
OK, could you please submit via the Submit tab on the system listing? That will allow us to keep a record of the submission.
Thanks.
jasonhouk
Uniden AlphaMan
Marion, Ohio
All,
When attempting to download the system using Proscan the system type shows TRBO which is incorrect. Should be DMR one freq trunk.
J
wa8pyr
Lead Database Admin
Ohio
That's how it's entered, as "conventional networked" which is equivalent to single frequency trunking.
If you can confirm that it's actually Connect Plus or similar I can change the entry.
jasonhouk
Uniden AlphaMan
Marion, Ohio
Then this could be a Proscan issue with importing?
I only know if its not programmed as DMR single freq in my 436HP its silent.
Thanks J
wa8pyr
Lead Database Admin
Ohio
Yes, most likely a Proscan issue; the system entry doesn't say anything about TRBO anywhere. I don't own Proscan so I'm unable to test it myself.
Try importing it as Proscan shows it, then manually change the system type to make sure it works.
