CS800D front panel freq entry?
Thunderknight
Bletchley Park
I’m looking at buying a CS-800D, but I can’t figure out if this is possible: using the front dial or microphone pad, can I enter an analog frequency that is not programmed into the radio?
E.g. I want to tune to 146.550 analog and I don’t have it preprogrammed. Can I do it?
I looked at the manual online and nothing seems to indicate any way to choose a channel other than those that are programmed in.
And if so, can I also pick the PL tone?
Is this one of those “unlock” in software features (for FCC compliance)?
Josh
Auburn Hills, Michigan
If the CS800D is similar in nature to the CS800, then yes you should be able to program the radio without a computer, but it needs to be provisioned by the software first.
-Josh
bharvey2
Call or e-mail them. They're usually very responsive. I'm sure they'll answer your question and expalin how to do what you want if it can be done.
