Cumberland County Fire Rescue Monitoring
emscapt9816
Retired, but somehow working harder now...
Coconut Creek, FL
Good morning All. I am trying to help out a friend with programming. He is a retired firefighter from my previous volunteer fire department, and he has relocated to Cumberland County. He currently owns a GRE PSR-410. He only wants fire frequencies. From my research, I see about a dozen conventional fire frequencies for the County and Townships. I also see an OpenSky system listed, which of course can't be monitored. The South Central Interoperability Network is listed for the surrounding counties, which will require an SDS-series scanner. So the questions are, do I just program the 11 or so conventional frequencies for him, or advise him to upgrade his radio? Will Cumberland County be changing their system to something that can be monitored, further justifying the radio upgrade? I know I would tell him to upgrade, but I don't know if he's interested in the surrounding counties, and if Cumberland County will eventually switch. Any help is appreciated.
Whiskey3JMC
DXpeditioner
40.0417240450727, -75.23614582932653
Post #5 in this thread seems to suggest Cumberland County is (or was as of 2019) in the process of upgrading from said OpenSky system to an 800MHz P25 Phase-II. Aside from that I'm not seeing any further conversation about the proposed new system. So I'm hoping others who may be in-the-know can chime in
kb3isq
Shippensburg, PA
The opensky is rebroadcast on several frequencies. 460.575, 453.175, 462.975, 460.375 and 453.700
emscapt9816
Coconut Creek, FL
Thank you. I didn't see these frequencies in the Database. Are there specific entities or designations to each frequency? Are PL codes assigned, or just CSQ?
Whiskey3JMC
DXpeditioner
Here's what is listed in the DB...
460.57500100.0 PLWNML658Vigilant Hose Company Operations RepeaterShippensburg Borough
Local Governments
CumberlandPA
453.17500458.17500131.8 PLWZZ999EMS DispatchEMS
Cumberland County
CumberlandPA
462.97500467.97500131.8 PLWZZ999MED 10 - Patched to trunked system EMS Dispatch TGEMS
Cumberland County
CumberlandPA
453.70000WNML658Vigilant Hose Company Repeater (Multicast from OpenSky)Shippensburg Borough
Local Governments
CumberlandPA
emscapt9816
Coconut Creek, FL
Local Governments
CumberlandPA
Cumberland County
CumberlandPA
Cumberland County
CumberlandPA
Local Governments
CumberlandPA
OK, thanks. Looking again at the page, I see them.
markandjere
Franklin County, PA
My recommendations for Cumberland County
46.06 Fire Dispatch
460.350 71.9 pl Fire Dispatch patched to Open Sky
460.575 100.0 pl not sure that this is still active
453.700 Fire Dispatch plus other ops multicast from Open Sky
453.175 EMS Dispatch
462.975 EMS Dispatch
463.000 Holy Spirit Hospital
463.125 Carlisle Hospital
463.150 West Shore Hospital
EMTBob
Mount Pleasant, Pennsylvania
Local Governments
CumberlandPA
Cumberland County
CumberlandPA
Cumberland County
CumberlandPA
Local Governments
CumberlandPA
453.700 Picked Up In McConnellsburg Traveling East Of 30 Thanks.
