BCD325P2/BCD996P2: DMR upgrade
tvengr
Well Known Member
Baltimore County, MD
In ProScan, Add System. Select DMR One Freq Trunk. Add Site (Frequencies). Add Channel (Frequency). Enter Frequency and Color Code. Add Group (TGID's). Add Channel (TGID). Enter TGID Name, TGID, and TDMA Slot. When you scan the system, I suggest that you put the system into ID Search. You may find a sheriff tac talkgroup using the same frequency with a different TGID. Each TDMA frequency has 2 audio channels (slots). You can have 2 simultaneous transmissions on a single frequency.
firetext911
Trumann, AR
Here is screen shots of all settings, I have not audio at all now.
firetext911
Trumann, AR
I do get signal bars and I do get audio but only for the few seconds then nothing.
I put scanner on hold and locked in on the site 01 and it is working.
Let me try this for a while and see if that did the trick.
Thank you everyone for your help and patience.
tvengr
Well Known Member
Click on SC in the upper right corner of the ProScan screen. I seem to remember that the Resume Scan/Search setting will cause the audio to cut out after several seconds. Hopefully, someone who is familiar with it will jump in.
jtwalker
BEE00.1E8
Yeah I was thinking along these lines too. Or just disconnect ProScan all together and see if problem persists and if it’s gone then follow @tvengr ’s advice.
