I'm trying to use my Airspy HF+ Discovery with DSD+. DSD+ never seems to be able to find the device. Other applications have no difficulty with using it.
Any suggestions as to what I have to be doing incorrectly or what additional information may be needed for you to be able to help troubleshoot? I successfully use the original freebie version of DSD just feeding it audio from any receiver to monitor a channel but the Fastlane version offers better performance and more extensive decoding information than that first version. No problem using DSD+ Fastlane with RTL dongles, either.
The following is what FMPA-cc .bat invocation produces -
D:\DSD+>FMPA -rc -o1 -f143.3850
FMPA 2.37
Current working directory is "D:\DSD+"
Airspy serial number list: C852838087C746F8
Spectrum window width: 1024
FFT size: 32,768
Spectrum update rate: 10 Hz
Step size table: 5.000 6.250 7.500 12.500 15.000 25.000 100.000
DSD+ path is "D:\DSD+"
Primary frequency list: '.\FreqList.csv'
Secondary frequency list: '.\FreqList2.csv'
Database search distance: 60.00 miles
Base latitude/longitude: 47.0338 -67.8059
Role is control/rest channel monitor;
Auto-starting control/rest channel following mode
Using WaveOut device #1
Initial frequency set to 143.385000 MHz
Optimizing FFT calculations... done.
Audio output device #1 = 'Speakers (4- Logitech USB Heads'
Audio output device #2 = 'Digital Audio (S/PDIF) (High De'
Audio output device #3 = 'Line 1 (Virtual Audio Cable)'
Audio output device #4 = '1 - LG IPS FULLHD (AMD High Def'
Audio output device #5 = '6 - LG IPS FULLHD (AMD High Def'
Airspy lib version = 1.0.11
Can't open Airspy device #1
Airspy device with serial number C852838087C746F8 is not present or is already in use
TIA,
Lee
FMPA 2.37
FFT size: 32,768
TIA,
Lee
