i've had very good luck using dsd v1.6, using mbelib 1.2.5, to decode a local 2m ham repeater ... my setup was a radio shack pro-2006 with the discriminator tap described at Discriminator Output PRO-2006 / COM-205 .. the only exception was i used a 10k ohm resistor not a 12k; the cap was 2.2n as described ... patched into the mic input of an old acer aspire running ubuntu 10.04 with an embedded realtek alc268 chipset based sound card that doesn't offer a line input - only mic in ... as mentioned this has worked flawlessly decoding dmr.
i recently obtained an icom r-8500 and i "created" a discriminator tap by following the instructions at Discriminator Output IC-R8500 ... using the same exact laptop with the r-8500 tuned to the same 2m repeater, i'm struggling to get a decode of it's dmr signal.
i used a breadboard and some spare resistors and caps of varying specification to see if i could stumble upon some combination that would help along with adjusting the input level of the mic input to no avail.
clearly there's something electrically different about the signal offered by the r-8500's disc tap as compared to the rs pro-2006.
anyone tried using an r-8500 with dsd that might offer some insight? otherwise, anyone have any advice on possible solutions?
