DSD+ and Tier 3 systems
GTR8000
NY/NJ Database Guy
BEE00
The latest release of DSD+ Fast Lane 2.448 has changed the way some Tier 3 systems are interpreted with regard to the System/Network ID and the site numbering. So far it has been confirmed to now display the Goosetown/Triangle system parameters correctly, however there are other Tier 3 systems in NY that should also be checked by anyone who is in the vicinity and is a Fast Lane subscriber.
East Mountain Communications
East Mountain Communications (T3 Hytera)
RadioMax Communications
SolarCity (Tesla)
Wegmans Food Markets
Please remember to submit any new findings with DSD+ 2.448 to the appropriate system as listed and linked above. Thanks!
k2hz
Rochester, NY
SolarCity (Tesla)
I am checking RadioMax and Wegmans and will advise results.
pro92b
Mutated Member
Here is East Mountain. DSD+ seems confused (or I am).
GTR8000
NY/NJ Database Guy
BEE00
RadioMax: L13-1.1 L13-1.2
Wegamns: L1-1 L1-2 L1-4
Okay so the RadioMax T3 Standard has not changed, and Wegman's CapMax has also not changed.
pro92b
Mutated Member
For L13 DSD+ also reports L12 like it doesn't know which one to settle on. My site and frequency files were unchanged and reflect L13.
GTR8000
NY/NJ Database Guy
BEE00
Ah okay I see that now. Can you temporarily rename or move your files so that DSD+ is not influenced by them when decoding?
pro92b
Mutated Member
I had to remove East Mountain data from the files. DSD+ would not run when the files were missing. Results are the same.
seagravebuff60
Short Bus Reject
If you put a leading semicolon in any of the DSD+ files, DSD will ignore that record
Example (Networks File)
Code:
;TIII, 1:13, "1:13 East MTN Trunk"
GTR8000
NY/NJ Database Guy
BEE00
Okay so it seems that initially DSD+ wants to label this L12 Site 1, then immediately switches to L13 Site 1.2
It's consistent, which is good, and it's definitely now showing the correct info for the Goosetown/Triangle system.
To recap:
  • The Goosetown/Triangle system is a Selex/Leonardo brand Tier 3 system
  • It appears that both East Mountain systems are Hytera brand Tier 3 according to DSD+
  • Wegman's is a MOTOTRBO Capacity Max system, a pseudo Tier 3 system
@k2hz can you confirm what RadioMax shows in DSD+ for brand, if any?
pro92b
Mutated Member
I created a copy of the entire DSD+ folder for test purposes. The files for frequencies, sites, groups, and radios had numerous entries for East Mountain. It was easier to just block delete those entries due to the large number of lines. When there is no further use for the test folder I will just delete the whole thing.
seagravebuff60
Short Bus Reject
After blocking out all my DSD+ Records for East Mountain. I turned to the active control channel of the Putnam Valley site, and this is what DSD+ is displaying. I left it running for approximately 10 minutes to see if it would change, and it didn't. SysID 12 and Site 7
I think you need to block out all of your current DSD+ Records. Otherwise, DSD+ will display the incorrect information because it is grabbing the info from the files instead of the "OTA" information.
Same is showing for the Beekman Site. SysID12 Site 5. (Altho the Negbor listing still shows area.site :rolleyes: )
The same is also showing for the Highland site. SysID 12, Site 2
I leave them all running for a bit, but i don't think any will change the system ID or site ID
scottjpalmer
This change (which curiously doesn't appear to be in the change log) is what I believe to be the fix for a long standing issue described here
It has indeed fixed the issue, the TIII (MOT) system in question now consistently identifies as H1-XX as opposed to sometimes identifying as H2-Y.Y area.site format.
What I am now seeing though is inconsistent behaviour on TIII (TAIT) systems here. One functions as it should, consistently identifying as area.site format. The other now behaves like the MOT system above used to where DSD+FL identifies it as H1-XX rather H2-Y.Y area.site format.
v2.444
v2.448
This system behaves the same as before the update
This system does not
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
That's not technically confusion. It captures the DMR sync, and it displays some generic data until it is able to identify that it is a Hytera system. As soon as it is able to identify it as a Hytera system it adjusts. This has always done this on typical TIII systems -- just sometimes it is able to detect the vendor type so fast that you don't see that confusion period.
pro92b
Mutated Member
Something still does not seem right. I took all the data files from the base file zip just downloaded and put them in the DSD+ folder. That overwrote whatever was there before and essentially wiped out any stored system data I might have had. Then I shut the computer down and powered it on. Nothing changed. I still see L12 initially and it changes to L13 and stays L13. This is on the Highland site as logged in post 14 by seagravebuff60. However he never shows L13 on his screenshot - it stays at L12. I am getting the signal from a discriminator tap feeding into the mic jack on the computer. The signal looks fine on the scope display in DSD+.
mtindor
FMP24 PRO USER
Hmm. Well keep the reports coming. And if possible, capture raw audio and either link to it in the forums or send it directly to dsdplusfastlane@gmail.com so that the author is aware and has something to work with. But just make sure and describe what's different in DSDPlus behavior from 2p444 to 2p448 with that particular system.
seagravebuff60
Short Bus Reject
I changed all my DSD+ Files with incorrect information to test and DSD+ is displaying the incorrect info that I put in my files. As soon as I deleted the incorrect info after a few minutes DSD+ went back to show the correct info.
This further supports my theory that the reason why DSD+ is showing SysID 13 is that the files reflect that and will display the incorrect information because it is grabbing the info from the files instead of the "OTA" information.
